Old 02-01-2015, 07:44 AM   #11
ChibullsAN's Avatar
is it coming in at the seam / stitch? When the bunk is new, the thread used to sew the canvas ends it's thin, to seal the hole the needle made, the thread needs to get wet a few times and it will swell up, sealing the hole. Sometimes it won't seal a particular hole for whatever reason. I have used a flexible, clear, uv/outdoor, temperature rated silicone to dab in the area that the water came in. This was done on the outside. If done carefully, you will never see the silicone. As long as the water is coming in through a needle/thread hole.
2018 Rockwood Signature Ultralight 8329SS
ChibullsAN is offline   Reply With Quote
Old 02-01-2015, 07:51 AM   #12
No it's coming from what looks like the rubber seal around the door frame, it's farther in than the seams. (i've tried to load a photo but it isn't letting me)
TMCCUTCHEN is offline   Reply With Quote
Old 02-01-2015, 07:56 AM   #13
ChibullsAN's Avatar
Oh ok. Well then I had the same issue, except I found it before it started. My door was straight but the seal did not seal on the corners. The factory had about a 1/2" gap between the foam in the corners & the corners weren't touching the foam. I added my own and haven't had an issue. If the door is warped or bent, now that's a different story. With that being said, I will be adding a rain/drip guard above the front and rear bunk doors for when they are closed for that time when they don't seal for whatever reason any more.
Old 02-01-2015, 07:57 AM   #14
I added the photos to my album.
Old 02-01-2015, 07:59 AM   #15
ChibullsAN's Avatar
Also are you sure that the bunk end itself isn't caught in the seal on the top? A great way to close your bunk ends is to close every door and window and turn on your 'create a breeze' fans. The bunk end will get sucked into the trailer and will allow you to ensure the canvass isn't in the seal. FYI.
Old 02-01-2015, 08:00 AM   #16
I agree with the rain/drip guard the Cruise Lite had one and it seemed to work. May be our first upgrade.
Old 02-01-2015, 10:42 AM   #17
Great idea! We closed it at the lot with one of us inside pulling the canvas to make sure it wasn't trapped. As soon as the precipitation stops here we are going to pull it open and check it out.
Old 02-01-2015, 12:17 PM   #18
Welcome from Ontario. Hopefully a quick and easy fix, nothing worse than an RV problem that takes the fun away from camping.
Kevin
tenttotrailer is offline   Reply With Quote
Old 02-01-2015, 12:23 PM   #19
ChibullsAN's Avatar
Actually the more I reread this the more I'm not sure I am clear how / where it is leaking. Post a pic and maybe we can clear this up for you easy. Is it leaking in the bunk when it's open ? Or leaking when its closed? Nothing worse than the wrong opinion or miscommunication. Let me know.
Old 02-01-2015, 12:50 PM   #20
It's closed up. I posted a link to pic
