Old 02-01-2015, 12:55 PM   #21
http://www.forestriverforums.com/for...1&d=1422816860
TMCCUTCHEN is offline   Reply With Quote
Old 02-01-2015, 12:58 PM   #22
http://www.forestriverforums.com/for...1&d=1422817065
Old 02-01-2015, 09:59 PM   #23
Jimandchris's Avatar
Hi, your links to the photos aren't working. I did look at them by viewing your album. If the leak is on the inside surface of the canvas like it appears, you may have a leak between the bunk end frame and the body. Could be a caulking issue or the frame not tight to the fiberglass. From my experience, if the water is getting past the seals, it tends to puddle on the outside surface of the canvas and you see it when you open up the bunk end. I would definitely contact the dealer and be sure to take lots of photos. Others can chime in but this leak doesn't look like a leak from unseasoned seams, especially since your bunk ends were closed. JMHO.
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
