12-14-2019, 02:17 PM
Are my trailer brakes working?
Hey all,
We are new to the RV life this year but so far, we love it. My truck does not have any auxillary brakes for a trailer. So, do the brakes on the trailer even work or do I need to do something special on my truck to have them be functional?
12-14-2019, 02:24 PM
Let's start with some more information
What truck, trailer, type of pigtail connector...
12-14-2019, 03:15 PM
Ah, yes, should've included that. Trailer: 2018 Rockwood 232esp. Truck: 2005 toyota tundra double cab. The pigtail I'm not too sure about. It is a standard 3 prong that was pre wired.
12-14-2019, 03:32 PM
Originally Posted by ttamnotrub
Hey all,
Trying to explain how to set up brake equipment on a trailer and tow vehicle could be pretty lengthy. I would suggest going to an RV Dealer or RV Repair shop and having an expert look at what you have and give you a quote on what is needed to set up your rig properly.
2019 Cedar Creek 29RE
2017 Silverado Duramax 3500
12-14-2019, 03:36 PM
It's a popup so likely to have surge brakes, but you'll need to tell us more or attach a picture of the tongue.
12-14-2019, 03:49 PM
15+ years ago I had a Coleman popup.....and it had electric OEM brakes.
Doing some searches on 232 ESP, I see one site that shows it having electric brakes.
If you can provide us pictures of your trailer hitch and the trailer wiring connection, we can provide a definite answer to your question.
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
12-14-2019, 03:51 PM
Three prong
Won't swear to it, but that pop-up may not have electric brakes with a three prong pigtail. Mine had mechanical brakes.
2018 Rockwood Mini Lite 2502ks
2019 F150 XLT SCREW 3.55 ecoboost 4x4 w/max tow pkg
12-14-2019, 04:07 PM
Specs says it has electric brakes.
OP should have a 7 pin round plug near the trailer tongue.
https://www.rvusa.com/rv-guide/2018-...232esp-tr35083
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
12-14-2019, 04:37 PM
Pretty simple. For electric.
You need a controller on the truck dash. A 7 point harness, not 3 at the rear.
You need a 7 point harness on the trailer.
A surge brake has a brake fluid reservoir on the ball hitch. 3 or 4 wire harness.
12-14-2019, 05:07 PM
It sounds like an '05 Tundra is not pre-wired for a brake controller.
OP will need to install something like this along with a brake controller. like a Tekonsha P3.
https://www.etrailer.com/Wiring/Curt/C57186.html
12-15-2019, 01:51 PM
Check out this link, which says the 2005 Tundra is pre-wired for a controller.
It also has a description of the pre-wire with a picture and other helpful information.
https://www.etrailer.com/question-38414.html
McCormickJim
2017 GT 31L5
12-15-2019, 02:01 PM
Brakes
We haul a 2012 FR T12DDST and it does have electric brakes. We bought the Tekonsa Prodigy 2 and my reasoning is that I want the trailer (TT) to brake a little before the TV (tow vehicle) or it could push you into a skid in wet or snowy weather. I know up in CO it is required to have traction devices but my grandsons and granddaughter near Hill AFB, UT have them and have needed them. The Prodigy 2 has adjustable braking and it is awesome. Go to Youtube.com and watch a couple videos. I would not be without one as in a skid it can actually straighten your vehicle out.
12-15-2019, 07:30 PM
What is the weight of your pop-up?
If you know what state was it originally delivered to. The reason I am asking is I had a pop-up. The dealership in VT ordered it without any brakes. Trailer weighed 1495lbs. VT law says only trailers over 1500lbs need breaks. That was several years ago laws could have changed.
I live in NYS whose law is any trailer over 1000lbs. The manufacturers sales rep had the dealership put new axle with electric brakes. The manufacturer paid the expense. The dealership then installed a brake controller on our TV.
I highly recommend having brakes on the trailer to help prevent fish tailing in certain situations.
Good luck!!
2017 Forest River Surveyor 251rks
2022 Chevy 3500HD High Country
12-15-2019, 07:57 PM
I've had different brake controllers with my previous 2 pop-ups and A-Frame. I got tired of being jerked at low speed and/or having inadequate braking at highway speed.
Finally broke down and bought a Prodigy 2 - cheaper than a Prodigy 3 because of the less elaborate display. What a difference! I set it up to where the camper brakes the same as the tow vehicle - I can't feel the camper push or pull my minivan. No more jerking. I love it.
Fred W
2019 Flagstaff T21TBHW A-frame
last trip: Nov, Chatfield State Park (near Denver, CO)
next trip: S Llano R State Park, TX
12-15-2019, 08:48 PM
Good luck!!
The OP's popup has a GVWR of 3844lbs, so it certainly has electric brakes. It's a heavy popup toyhauler. Its fictional dry weight is 2933lbs.
The OP is going to need a brake controller.
12-16-2019, 05:20 PM
Brakes
If you decide you need a brake controller, there is a Toyota wire kit that plugs into the back of the Prodigy unit. I got the one for my Tundra from E-Trailer. It plugged into the fuse box under the dash. They also had a plug in connector that converted the wiring to a 7 wire plug, no wire splicing. You just disconnect the TV wiring and plug the adaptor in.
