Old 07-21-2016, 06:54 PM   #1
VRB
Awning Issues
Being a newbie with an electric awning... Do you extend and retract it with the wheels tight or loose? (Sounded much better with the wheels being loose.) Tks!
VRB is offline   Reply With Quote
Old 07-21-2016, 06:57 PM   #2
crunchman12001's Avatar
Loose, you only tighten to pitch the awning once extended.
2015 F-250 FX4
Old 07-24-2016, 05:46 PM   #3
logspec1's Avatar
Awning Issues
Loose. They will tell you you can raise and lower the awning with them tight but it puts a lot of stress on the motor and is not worth the risk. Put that on your check list to ensure the nuts are loose. You won't regret it.
Ken
2017 Rockwood 8329SS
2012 Ford F250 King Ranch
6.7 TD Super Crew
"Go Navy"
logspec1 is offline   Reply With Quote
Old 07-24-2016, 06:47 PM   #4
Georgia Rally Coordinator
aceinspp's Avatar
Welcome to the forum. Lose when extending and then tighten after its out and make sure to put one side lower tha other just in case you get a slight rain. Enjoy Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 07-24-2016, 06:54 PM   #5
I leave mine loose all the time, even when deployed. I use the awning poles to set the tilt.
Old 07-24-2016, 07:10 PM   #6
asquared's Avatar
X2....use OC's awning poles and turbs brackets with tie downs to set the tilt. Always leave th knobs loose do don't forget about them.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-24-2016, 07:59 PM   #7
Not trying to hijack the thread, but being another newb, I was wondering what knobs/nuts we're talking about? I don't see anything like that on mine. Can someone post a pic? Mine's a Solera.
Sent from my SD4930UR using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 07-24-2016, 08:14 PM   #8
Black knob on awning arm.
2015 F-250 FX4
Old 07-24-2016, 08:43 PM   #9
asquared's Avatar
Do you have a power or manual awning?
2014 Sabre 34REQS-6
Old 07-24-2016, 08:46 PM   #10
It's power, and it doesn't have the same config as crunchman's pic.
Old 07-24-2016, 08:57 PM   #11
northstar1960's Avatar
Leave them loose unless you want one end or both pulled down . if you just leave it out and loose then it will auto dump any rain water if it rains
northstar1960 is offline   Reply With Quote
Old 07-25-2016, 06:34 AM   #12
logspec1's Avatar
Awning Issues
Gspot01,
What type RV do you have? I believe you might have the scissor type awning. I do not believe they have these knobs/nuts. So for you it would not be a problem.
Ken
6.7 TD Super Crew
"Go Navy"
Old 07-25-2016, 06:51 AM   #13
If Your awning is a "Carefree of Colorado" Yes you have the OP has Knobs! Youroo!!
Old 07-25-2016, 07:17 AM   #14
Stormrider151's Avatar
LCI awnings don't have the knob. They have an articulating arm to set the pitch of the awning.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 07-25-2016, 07:35 AM   #15
Yes, that must be mine then. Sorta wish I had the knobs, because those articulating arms don't work. Right after I pull them down to set the pitch, they straighten back out again and the awning pops right back to its original position. That's sorta why I was interested in this thread, hoping I was missing something about some knobs to tighten it up.
awning
