Old 07-21-2016, 07:54 PM   #1
VRB
Awning Issues
Being a newbie with an electric awning... Do you extend and retract it with the wheels tight or loose? (Sounded much better with the wheels being loose.) Tks!
VRB is offline   Reply With Quote
Old 07-21-2016, 07:57 PM   #2
crunchman12001's Avatar
Loose, you only tighten to pitch the awning once extended.
2017 Salem Villa Estate 395RET-Coming soon
2015 F-250 FX4 SUPER DUTY 6.2L Gas 4WD SuperCab XL 3.73 rear / 158" WB / 8' bed. Factory anti-sway and brake controller
crunchman12001 is online now   Reply With Quote
Old 07-24-2016, 06:46 PM   #3
logspec1's Avatar
Awning Issues
Loose. They will tell you you can raise and lower the awning with them tight but it puts a lot of stress on the motor and is not worth the risk. Put that on your check list to ensure the nuts are loose. You won't regret it.
Ken
2017 Rockwood 8329SS
2015 GMC Sierra 1500
"Go Navy"
logspec1 is offline   Reply With Quote
Old 07-24-2016, 07:47 PM   #4
Georgia Frog Rally 2017
aceinspp's Avatar
Welcome to the forum. Lose when extending and then tighten after its out and make sure to put one side lower tha other just in case you get a slight rain. Enjoy Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 07-24-2016, 07:54 PM   #5
I leave mine loose all the time, even when deployed. I use the awning poles to set the tilt.
Old 07-24-2016, 08:10 PM   #6
asquared's Avatar
X2....use OC's awning poles and turbs brackets with tie downs to set the tilt. Always leave th knobs loose do don't forget about them.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is online now   Reply With Quote
Old 07-24-2016, 08:59 PM   #7
Not trying to hijack the thread, but being another newb, I was wondering what knobs/nuts we're talking about? I don't see anything like that on mine. Can someone post a pic? Mine's a Solera.
Sent from my SD4930UR using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 07-24-2016, 09:14 PM   #8
Black knob on awning arm.
Old 07-24-2016, 09:43 PM   #9
asquared's Avatar
Do you have a power or manual awning?
2014 Sabre 34REQS-6
Old 07-24-2016, 09:46 PM   #10
It's power, and it doesn't have the same config as crunchman's pic.
awning
