Old 02-01-2017, 02:04 PM   #1
Battery life
Hi seasoned RV pros,
Roughly, how long should the battery last for the heat when boondocking? Have a generator onboard but not sure if I can expect to have enough power to fire up the generator in the morning???
BruceAndGlo is offline   Reply With Quote
Old 02-01-2017, 02:15 PM   #2
The furnace fan can easily kill a battery overnight. Lots of threads here on this issue. Most folks add extra batteries.
2011 Traverse LT, 3.6L, FWD
Old 02-01-2017, 02:18 PM   #3
Insert witty title here
It really depends on the size of your battery, how cold it is outside and how warm you like your camper to be. I have a pair of 90AH deep cycle batteries which will run my furnace all night.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 02-01-2017, 02:30 PM   #4
X2. This really says it all.
Don't expect a single battery to get you through the night if it's cold.
Propane won't last but a couple days either!
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 02-01-2017, 03:30 PM   #5
bikendan's Avatar
If you only have a single battery in your Sandpiper, you need get at least a dual battery setup, if you plan on dry camping or boondocking.
Old 03-14-2017, 08:46 AM   #6
Good advice! I changed to 2 6V batteries and that is barely enough through the night when it's in the low 20s so looking at two more next.
battery
