Old 03-25-2014, 06:49 AM   #11
Originally Posted by RickV View Post
On my old 2006 Rockwood 8290SS I had the Sidewinder. I liked the fact that if I had to park in a tight spot at a weird angle hooking back up was much easier. I could just move the Sidewinder to line up with my hitch.
That's a good point on the Sidewinder option. The Superglide requires you to be pretty much straight when you connect or disconnect. But then again...I figure if I have to be at that much of an angle to get connected, then I probably don't need to be there in the first place.
2012 Palomino Sabre 32BHTS
2008 GMC Sierra 2500 SLE 4x4 Duramax
clange is offline   Reply With Quote
Old 03-25-2014, 06:57 AM   #12
Originally Posted by Cajun Po-Boy View Post
If your just a weekend warrior camper...an auto slider or for the same money a cheap fix hitch with sidewinder pinbox.
If you like easy & forget about it type of things... the Pullrite slider is sweet.
If I was to full time it...I'd consider the expensive air bag style pinbox setup and a quality hitch.
X2
Old 03-25-2014, 03:20 PM   #13
Brookman62's Avatar
Originally Posted by clange View Post
I can only comment on the hitch as I have a pickup similar to yours. I have a Pullrite Superglide automatic slider and absolutely love it. Our pin box is the standard pin box from the factory.
I just bought the Pullrite 16K for my F150 s-crew. I read a lot about the hitches and found that the one piece "wrap-around the pin" design of the Pullrite makes a tighter connection than the Reese "split-jaw(two piece). The Pullrite one piece design prevents "chucking" between truck and fifth wheel, in stop/ go or decel/ accel driving conditions. I bought it through Amazon.com'
I can't tell you how it works yet because we are still waiting for our new fifth wheel, on order... can't wait! Hope this helps you...good luck!
'05 F150 Crew Lariat 5.4L, '15 Flaggstaff Super-Lite 8528 TBWS...and 3 Aussies
Brookman62 is offline   Reply With Quote
Old 03-25-2014, 03:31 PM   #14
another_newfie's Avatar
Reese 16K manual slider for my combo. I can't complain, it has been fine. I don't have a comparison from personal experience since it is my first 5'r. No major issues, simple design, virtually no maintenance etc. I have friends that have the pullrite and they seem to like them.
Totally up to you of course, do the research and pick one; hitch up and GO! You have mentioned that you are not adverse to buying a larger hitch for a potential future upgrade; that should at least factor into your decision since you have mentioned a future upgrade. It'll probably happen at some point. What is it about RV's and 2 foot-itis...
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 03-25-2014, 08:37 PM   #15
bbeyor's Avatar
Best fifth wheel and pin box combination
Thanks for all the replies! A lot of great points. Obviously this a new experience for me and my family. Growing up I went to camp....didn't bring camp with me lol. I certainly appreciate the help.
bbeyor is offline   Reply With Quote
Old 03-25-2014, 08:52 PM   #16
TTNewbees's Avatar
I have a pull rite superglide 18k and it works phenomenally but extremely expensive but in my truck (short bed) sloped driveway and 90 degree turn that's what I needed. I think it's case dependent and customer need. Tell a Chevy guy he needs a ford and ford guy says you need a Chevy. Seems to be the same round here with hitches.
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 03-25-2014, 08:58 PM   #17
So how do you know it prevents "chucking" if you don't have the 5er? I have the Reese 16K and it doesn't "chuck". Advertising propaganda I suspect. Regardless, I'll keep my 'el cheapo' as I like running with the tonneau cover on.
Old 03-25-2014, 09:13 PM   #18
I have a 20k super glide auto slide hitch that I no longer use. I am interested in selling. Let me know if you can use it.
Pittston RV is offline   Reply With Quote
Old 03-26-2014, 06:00 AM   #19
Brookman62's Avatar
Old Coot,
As I said in my post, I did a lot of reading , but I also asked a lot of 5'ers at a recent Camping show. I also talked to 3 different hitch installation outfits, one at the show, and 2 in my area here. I don't like to jump into a purchase... Reese is probably good for you, though.
Brookman
Old 03-26-2014, 06:05 AM   #20
dcheatwood's Avatar
I have Reese 16 k with ez slide (and don't need it) with revolution pin.
Sent from David's RAZR M.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
fifth wheel, wheel
