Old 03-16-2015, 04:17 PM   #1
Big Foot leveling jacks problem
Hi, when we enter our motorhome the bigfoot panel is beeping and the right-front leveling light is flashing. We checked under the motorhome and all the jacks are up. Can anyone make a suggestion as to what is causing this problem and how to fix it. Thanks you.
Gorman is offline   Reply With Quote
Old 03-16-2015, 06:18 PM   #2
Average Joe
MrJoe's Avatar
Have you pressed the retract button to see if the beeping stops?
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 03-16-2015, 06:37 PM   #3
big foot leveling
Had that problem. The jack plate was not making contact with the sensing switch to tell it the jack is up. fixed it temporarily until a new jack and jack plate can be ordered.
5hfarms is offline   Reply With Quote
Old 03-16-2015, 06:50 PM   #4
bubbles's Avatar
On my older unit with Bigfoot Levelers it had a plunger switch on each strut and sometimes I had to lower the jack pad some and push the plunger rod in and briskly release a few times. Took care of the situation. I think the plunger rod was adjustable with a common screw driver.
Old 03-16-2015, 06:54 PM   #5
Witch Doctor's Avatar
Try to level if the system shows level then try to relevel, then let it do it's thing then hit retract all and see what happens. If that will not work try to reset to zero. If that will not do it you could have a bad sensor but I have never heard of that as a problem yet that I have seen. Most stuff is just user error the systems are pretty reliable. Lets hope yours is. Just a week ago a guy had a grounding error. What it came out to be was that the stroke of the ram couldn't go any farther. He had to retract and put a block under that one ram, yet had 30 reasons why it wouldn't work. Try the easy stuff first. Also lippert is your best friend right now and they will walk you through it as they did him...Good Luck... PS: will it work in the manual mode?
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
jacks, leveling
