Old 01-20-2014, 10:31 AM   #11
Check your garage service! You have 30 Amp service in the trailer drawing from a 15-20 amp garage circuit. If you plan to plug in at home a lot get a 30 amp service line in place. If you are not going to run the TT at "full power" while home you maybe ok,(not wise) but you may not pull enough juice to charge the battery. Your best bet spend a couple bucks get 30 Amp service to the garage.
David 01 is offline   Reply With Quote
Old 01-20-2014, 01:02 PM   #12
Thanks. I called the dealer and they believe the converter is wired into the outlet that won't reset thus causing all of the issues. Hopefully taking it there this afternoon.
Teacher travler from Alabama
ajaygirl is offline   Reply With Quote
Old 01-24-2014, 08:16 PM   #13
Welcome aboard
RedDragon is offline   Reply With Quote
camper
