Old 09-03-2012, 09:53 AM   #1
Breaker for 2011 29 qbbs slideout
Will someone please tell me where the breaker is for the 29 qbbs slideout?
I can only move this with my battery for now.
Your help is greatly appreciated.
Mickeybob is offline   Reply With Quote
Old 09-03-2012, 10:06 AM   #2
Hello, and to the forums. Hope you enjoy the stay, and learn a lot, and can teach others what you already know.
Your breaker may be hidden very well. The best way to find it, start at the positive post of the battery, and chase the positive wire. It will go to one or more breakers, usually small gray boxes with wires screwed down on studs. One end will be a very small reset button, it will be hard to see or find, but it is there. If there are more than one of these breakers, one will be for slides, others will run the camper. Good Luck.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 09-03-2012, 11:24 AM   #3
Thanks for the flip flop windrider. I found the cable was attached to a stud and pressed what I thought was a tiny black reset button -- but no success
Old 09-03-2012, 11:42 AM   #4
If you have a meter, check from ground to both studs. If the breaker is working, should have 12 volts on both. If it is tripped, will have 12 volts only on one side. Some people have to use a pen or toothpick to press the reset all the way back, depending on mounting location and finger size.
LadyWindrider
Old 09-03-2012, 12:32 PM   #5
bikendan's Avatar
it might help if you also posted the brand and year of your rig.
not sure who makes the 29QBBS.
Old 09-03-2012, 05:17 PM   #6
Talking Breaker for 29 qbbs slideout
Bingo windrider!
Thanks for stickin' by!
Mickeybob
breaker
