Old 12-29-2013, 10:07 AM   #1
cable hook-up
Hi I am new to this forum. I have a 2012 coachmen cattalina. Satelite will not work through cable outlet on outside of trailer. It does work if hooked directly to satellite receiver. Any suggestions?
pamela j is offline   Reply With Quote
Old 12-29-2013, 11:21 AM   #2
kc8lvy's Avatar
Welcome to the forum!! Do your connections inside aux? This is where I hook mine at.
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 12-29-2013, 11:25 AM   #3
Professional Curmudgeon
wrvond's Avatar
I don't have satellite, but, it should simply be a matter of turning the amplifier power switch off.
When the amplifier power switch is on, the antenna function is enabled, allowing only the signal from the roof antenna to get to the television. When it is off (button up green light off), it allows the signal from the cable (or in your case, satellite) to reach the television.
2014 Coachmen Catalina 253RKS
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 12-29-2013, 11:36 AM   #4
I tried that did not work thanks anyway
Old 12-29-2013, 12:37 PM   #5
caper's Avatar
My trailer has a hookup for cable and sat. on the outside. If I use the cable connection the sat. will not work (wrong coax).
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 12-29-2013, 12:53 PM   #6
Thanks mine only has one connection in back and one connection in front neither one says anything or works
Old 12-29-2013, 01:04 PM   #7
RKR
RKR's Avatar
If you only have one connection in the front and one in the back is sounds like maybe you're just wired for cable. The satellite will not work with cable wire (coax).
Is you're trailer wired for both satellite and cable ?
RKR is offline   Reply With Quote
Old 12-29-2013, 01:11 PM   #8
wrvond's Avatar
The Catalina's are wired for antenna and cable only.
Having no experience with satellite, I didn't know if it would work on cable coax or not. Apparently the answer is, it will not.
Sorry, Pamela; it looks like you are going to have to mod your camper, or run a separate cable through a window.
Good luck.
Old 12-29-2013, 01:22 PM   #9
Thanks everyone it sounds like I have my answer. I must be wired for cable only
Old 12-29-2013, 10:29 PM   #10
wrvond's Avatar
Pamela,
I just finished reading an article on e-how, where they say that satellite TV can use the same cable as CATV.
They say RG-6 is preferable, but that RG-59 can work, just not as well. In either case, you should still get a picture.
My first question is, have you ever used the cable input before? Do you know that it works?
If you've never used it before, then you are going to have to open up the connector box to:
1. ensure the cable coax is connected at the box
2. test for continuity on the cable coax
