Old 07-11-2015, 09:01 AM   #1
Cannot Locate exterior cable tv hook up
Hi first nite using this wildwood xlite camper trailor unit has a satleight on top ( no interior switch or lever to raise roof antenna) is there a spot on this camper to actually plug in my 10 foot cable line??
Dhelvey is offline   Reply With Quote
Old 07-11-2015, 02:23 PM   #2
bikendan's Avatar
i can guarantee you that your wildwood does not have a satellite on top.
do you have a crankup tv antenna? there's no switch or lever, just a crank on the trailer's ceiling.
have you got up on the roof to look?
some of the entry level trailers, like the wildwood x-lite, have tv hookups as an option, not standard.
if it does, the outside cable plug is usually under a covered hinged lid.
this should have been covered during the PDI from the dealership.
Old 07-11-2015, 09:50 PM   #3
jtstromsburg's Avatar
Does your antenna look like this? If so, it's just a digital antenna, not a satellite dish. Nothing to raise or point either, just turn on the booster switch, which should be on the wall plate your TV is connected to.
If you are trying to plug into park cable, look for a cover outside your rig, probably near water connections.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
cat, exterior
