Old 08-15-2008, 07:25 AM   #1
Dometic refrig
Refrig model 2652 exterior auto light on, inside light is on,but refrig/freezer isn't working. Need help asap leaving on trip today
thanks for any help
dcart46 is offline   Reply With Quote
Old 08-15-2008, 07:34 AM   #2
Welcome to FRF.
Did you just turn the fridge on or did you turn it on yesterday. Are you running it on gas or electric? If gas, is the gas on and air purged from the lines? I have to purge the air every time by firing up the stovetop which is near the fridge before the fridge burner will light. And they usually take about 12 hours to really get to cooling.
aintgotnun is offline   Reply With Quote
Old 08-15-2008, 07:41 AM   #3
Running on electric, refrig has been on suddenly stopped cooling. Thanks
Old 08-15-2008, 07:47 AM   #4
possible amonia leak??
also isn't there a recall going on for Dometic fridges??
Old 08-15-2008, 07:49 AM   #5
recall info clicky
Old 08-15-2008, 07:50 AM   #6
Brought 2000 salem lite tt used, refrig had been working fine,didn't know about recall or if its already been taken care of.
Old 08-15-2008, 07:56 AM   #7
Thanks for recall info, could there be a blown fuse to the refrig?
Old 08-15-2008, 08:03 AM   #8
may check the fuse pannel, I'm not sure about one in the fridge itself
Old 08-15-2008, 08:13 AM   #9
New to all this , how would i know which fuse is for the refrig in the fuse panel?
Old 08-15-2008, 08:17 AM   #10
"should" be marked on a sheet on the door or below the fuses. if not start pulling fuses and look for a blown one.
yeah I know, not much help
