Electrical Understanding
Not new to camping, or trailers, but I just brought home my first 5th wheel and it has stuff I've not had before. Rather than ask you to explain, I'm looking to see if I understand what I think I understand.
Shore power is a no brainer, except one question. This is the first rig I've had with a 50 amp hook up. The trailer has an electric fireplace (aux heater). The dealer told me at walk through that he couldn't show me how it worked because we were hooked to 30 amp. Does that sound legit? Does 50amp typically give you access to devices that 30 amp won't? Like aux heater or second AC?
The trailer has 4 6 volt batteries. I think the rated amp hours gets doubled, but not x4. X2 would be around 400 amp IIRC, maybe 480. But you can really only use half of the full number, so in reality I have around 200AH usable. That could be divided up a multitude of ways, but in theory it's berween 1amp for 200hrs or 200amps for 1 hr.
I have 2 160watt solar panels, 320 total, duh. I'm not really sure at the moment how many amps the controller is (or is it called a converter?) But Im certain it won't charge as fast as I can drain. I view them as dumb but quiet recharge helpers. I believe they work all the time, so long as the sun is shining. I got them with the idea of keeping batteries topped off all the time when we're not using the rv, and to supplement a daily generator recharge a little when we are using it.
I have 2 Yamaha 2000 inverter gens with the pigtail for 30 amp. I "think" I can recharge a days use of battery AHs by running them a while. Not sure really what a while is, depends on battery use I guess, but I'm thinking that running them long enough to cook supper, watch a movie, ought to recharge a normal days battery use.
I have no inverter yet. I plan on getting a 2000 watt magnum before we go full time. I know that we won't be running micro or A.C. on that, but probably a couple hrs TV, maybe 20 min of 1500 watt air fryer on occasion, maybe a small fan in the bedroom on hot nights, that kind of stuff.
Am I on the right track? Remotely close? What about that 50amp vs 30 amp shore power problem? Is the dealer right, or did he snow me?
