Old 09-15-2016, 06:51 PM   #1
first day in this forum- 2016NITRO ISSUES
I own a2016 forest river NITRO 305 Toy hauler.
just wondering if anyone else has had the same issues I have faced so far.
With the a/c units on-either separately, or one at a time, the fan will turn off and change speeds. high to low-many times an hour.
We live in the desert-so having the fan on the high speed is a must!
came with dometic digital t stats.
any help is appreciated, thanks to all !
kitshop1 is offline   Reply With Quote
Old 09-15-2016, 07:23 PM   #2
bubbles's Avatar
Select HI for the fan speed instead of AU. The fan speed will automatically switch to LO when the temp gets to within about 4 degrees of the thermostat setting when fan speed is set to AU. It will auto switch back to HI at a predetermined difference from thermostat also when fan speed is in AU. When you start to use your furnace be sure to set the fan speed to AU.
Old 09-16-2016, 09:38 AM   #3
Head Rambler
X2 ^
Whoever designed these thermostats failed to test them in real world scenarios. There have been a lot of complaints on how they work as well as a good number of failures of them.
Gotta go campin!
