Old 07-06-2015, 03:47 PM   #1
Mike, Glenda & Rocco
First time owner-making a punch list
We bought our first TT (Heritage Glen 272 RLIS) 3 weeks ago and have been on 3 trips since. We absolutely love it. But as with pretty much any new home, there are things that need to be corrected. Because it's new and still under warranty and because I have to drive 200 miles each time it goes to the dealer, we are trying to make sure that we identify everything that needs to be corrected so that we can get it all done at one time. We have a punch list of things that we have identified, but neither of us knows much about TTs. Does anyone have any suggestions on things that need to be checked other than the obvious dead plug or loose trim?
Rocco1Dog is offline   Reply With Quote
Old 07-06-2015, 04:17 PM   #2
I'm new at trailers as well. All I can say is use everything as much as possible. Write everything down whether you think it's an issue or not and even if you fix it. Make sure you open and close all windows, awning, ac, furnace, everything.
Open all cupboards, drawers, open any panels, doors that the winterizing valves, water pump are behind. The more you look the more you will find and get repaired on warranty.
Carrier is offline   Reply With Quote
Old 07-06-2015, 06:29 PM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
Welcome to the forum. Yes check every thing you can even put water in the in your fresh water system and try the water pump to make sue it works also. Check heating and AC so that they function as they should. Any thing you can also think of. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
first time
