Old 10-16-2016, 09:20 AM   #11
What I don't understand is why he's getting hot water for a very short time and then going cold. That tells me water is getting into the tank thru open valves and is being heated. Not warm, but truly hot!
gfarmcafe is offline   Reply With Quote
Old 10-16-2016, 09:54 AM   #12
Welcome to the forum. Make sure the valves are turned all the way to the on position. Could be someone didn't turn the valves to full on.
Wattsworld is offline   Reply With Quote
Old 10-16-2016, 10:23 AM   #13
Georgia Frog Rally 2017
aceinspp's Avatar
Have you found the 3 valves for the by pass? As mentioned make sure valves opened all the way for the hot and cold water and turned parallel to the line and center valve turned perpendicular to water line. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 10-16-2016, 10:42 AM   #14
Briorick's Avatar
With the valves not in their correct positioning, Cold water, via water pressure, is allowed to cross over and mix into the Hot water side causing spurts of "hot" and then "cold" water flow when in use.
When your water flow is idle in the HW tank and not interrupted by turning on the faucets, etc., the water in the tank will reheat and then when needed it will flow out first as hot, and then back to cold again. It will only keep repeating this process until the valves are in their corrected position.
Need to make sure the valves are in their correct summer mode.
When we had our previous HTT we ( newbies then ) had to learn the hard way as well. We had the SAME issue. Once corrected...we were good to go.
Rick & Brian
1 Happy Camper Pup ( Mya )
2016 Salem Cruise Lite 171RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 10-16-2016, 10:42 AM   #15
Yep. Just noticed the hot and cold were in line but the bypass was also in line. I believe the bypass needs to be the opposite. Thank you for your response.
salvadorie1 is offline   Reply With Quote
Old 10-16-2016, 11:22 AM   #16
Ford Idaho's Avatar
You are correct.
Turn the bypass valve all the way to what will be the closed position.
Old 10-16-2016, 11:49 AM   #17
Thank you . I think its working now.
Old 10-16-2016, 12:28 PM   #18
Ford Idaho's Avatar
first time, trailer, travel, travel trailer
