Old 08-13-2016, 12:12 PM   #1
Ford 6.8L V10 Normal Temp
Howdy, anyone know what temp. the thermostat is on a 2016 E350SD Cab Chassis Class C. On our last trip, the outside temps where 90 to 95 and the temp. on my Scan Gauge was reading 197 to 204. Is a 7 degree range normal?
markb422 is offline   Reply With Quote
Old 08-13-2016, 08:46 PM   #2
My 5.4L is on 195 so yours is probably the same. When towing I run 198 to 206 normally. The fan kicks into high gear at about 215 which has happened at couple of times. It is loud.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 08-13-2016, 08:51 PM   #3
No-Fish's Avatar
temp
Ive got 2 v-10's, 2001 F350 and a 2016 E450..temp runs around 199 to 205 on both
No-Fish is offline   Reply With Quote
Old 08-13-2016, 09:42 PM   #4
I have an 2004 in a n F-250 pretty constant at 200 when towing. (B&W temp gauge)
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 08-14-2016, 05:18 AM   #5
ilmor's Avatar
Sounds normal to me. Heck, my Wrangler was 206 yesterday while cruising an interstate (100 degs. outside).
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
ilmor is offline   Reply With Quote
Old 08-14-2016, 06:29 AM   #6
Forgot to answer the question.. 195F
Old 08-14-2016, 07:42 AM   #7
Temp. ?
Boy you guys are up early today reading forum post. Thanks for the replies. I am first time Ford owner and liking it so far. My van which I think has a 190 deg. thermostat would normally run 191 to 195 towing in 90 deg. outside temps. Good to know the v10 runs a little warmer.
ford
