The class A’s may be the only ones with the factory installed option, but a generator switch is a generator switch...as long as your generator allows the auto-start on loss of power feature, you can get an ABT (automatic bus transfer) switch that will switch to the generator when power is lost. May have to contact a commercial electrician and do it yourself, potentially voiding a warranty, but yes, you could do it pretty easily if you can find the parts and your generator supports it.
