Old 04-06-2014, 11:41 AM   #1
Furnace
I'm in the process of de-winterizing and I notice a round metal plate on the furnace blowing warm air in the water heater area. My question is the round metal plate suppose to be off or has it come off and needs to be replaced.
mike.reece is offline   Reply With Quote
Old 04-06-2014, 12:32 PM   #2
Todouble's Avatar
Can you post a pic. Not sure what your referring too.
Todouble is offline   Reply With Quote
Old 04-06-2014, 12:37 PM   #3
WrongWayRandall's Avatar
Also, if you could put your equipment in your signature we would know a bit more about what you are working with.
- Randy
1975 Westfalia (VW)
2014 Rockwood A122
WrongWayRandall is offline   Reply With Quote
Old 04-06-2014, 12:39 PM   #4
Wildwood 27 Tbss, I will post a picture, Thank you
Old 04-06-2014, 12:46 PM   #5
Pic
Sent from my SM-N900V using Forest River Forums mobile app
Old 04-06-2014, 12:48 PM   #6
It seems common sence that it would be on so it would push more warm air to the vents, but I just wanted to be sure
Old 04-06-2014, 12:50 PM   #7
Todouble's Avatar
Furnace
That looks like an additional outlet to attach a flex duct and feed a supply register with. The furnaces have a bunch but not all units use them all so they use blank off plates for unused ones. That need to go back on.
Old 04-06-2014, 12:52 PM   #8
Originally Posted by mike.reece View Post
Pic
Close it and use the alum furnace tape to seal them and any others not used.
Old 04-06-2014, 01:09 PM   #9
Fantastic, Thanks so much for your help, Have a great day
Old 04-06-2014, 02:04 PM   #10
Witch Doctor's Avatar
Todouble is correct but before you seal it up, make sure that is not used to heat your under belly for you water pipes and tanks. Also I would check and see how many ducts you have connected. If you can not vent the correct CFM you are going to have a problem with the limit it not as easy as just taping it closed. I would do a little more research on it first. I did not see a duct on the other 4" outlet........ infact I do not see any ducts coming off the plenum. What unit do you have and what model furnace. How many registers do you have in the floor or low wall?
Coachmen M/H
Concord
2018 / 300 DSC
furnace
