Old 02-17-2013, 07:25 PM   #1
Unhappy Gas pressure Low
I have a propane pressure issue that I just can't figure out.
I have "T"ed into my main gas line that runs to my stove, furance, fridge etc. with a new quick connect. The applicances inside the trailer are working very well with never any issues. From this "t" I have placed in 20 feet of flexible new gas line that goes into a older coleman stove, (two Burner), I have taken out of the line going into the coleman the regulator as I know that I would reduce the pressure from the twin regulated bottles in my fifth wheel too much. Just prior to the coleman I have place another "T" that runs to a small table top BBQ. I have placed in new quick connectors on all of the feeds.
I am getting so little pressure either of stoves, a small wind could put out the flames. I have checked for any blockages in the lines, correct functioning of the quick connects etc. I have even turn on the gas very slowly not to trip the safety regulator on the tanks.
Basicly I have straight through lines to both coleman and bbq, the only requlator I have is on the main tanks. I have also replaced the regs on the main tanks, I thought they may be sticking or weak.
I just don't know what I'm missing. Any body have any hints what I might try out.
jshwets is offline   Reply With Quote
Old 02-17-2013, 07:30 PM   #2
AquaMan's Avatar
Are your other appliances operating correctly? furnace, fridge, oven?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-17-2013, 07:45 PM   #3
Thanks for the reply. Yes, all the applicances in the trailer are working very well.
Old 02-17-2013, 08:03 PM   #4
If I remember correctly the coleman stove uses a higher pressure regulator.
The regulator on the camper is set at a lower pressure than the stove requires.
Papa Roo is offline   Reply With Quote
Old 02-17-2013, 08:08 PM   #5
bikendan's Avatar
your problem is using a high pressure stove, on a low pressure system.
you have to take the Coleman's regulator off.
only stove that can be used without mods, is the Camp Chef stoves. they work on low pressure.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 02-17-2013, 08:09 PM   #6
caper's Avatar
Try putting the "T" before the regulator. As stated the trailer works on low pressure and the stove and BBQ both need high pressure.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-17-2013, 08:10 PM   #7
Terier's Avatar
I'm not very technical and can't offer any feedback but to the forums!
Old 02-17-2013, 08:22 PM   #8
No regulators are left on the line to the bbq or the stove. I have removed them, knowing that they run on low pressure. I removed them due to the existing ones on the trailer. The "T" or the quick connects really do not have any restrictions either. Hence why I am so stumped!
