Old 01-12-2016, 06:16 AM   #1
Geetings from Grand Isle, Louisiana
Hello, we purchased a used 2014 Flagstaff 21fbs and we are currently on a shakedown trip here at Grand Isle State Park. I've been browsing and I'm having trouble finding information on where the water heater bypass is on this model. (No owner's manual). Also need to know where the breaker panel is located. Enjoying our second home tremendously, but could use more hot water. Any help would be appreciated. Thanks!
bayoudonnie is offline   Reply With Quote
Old 01-12-2016, 05:49 PM   #2
Major's Avatar
Sorry can't help as I am not familiar with the Flagstaff but you might try posting in the Flagstaff area and maybe someone there can help.
Anyway, welcome to the forum.
Doug and Becky Ridgeway
2014 Blue Ridge 3600RS
2014 Ford F-350 CC 4X4 DRW 6.7 PSD
Troy, NC
Major is offline   Reply With Quote
Old 01-12-2016, 06:03 PM   #3
Ford Idaho's Avatar
Welcome to the forums from SW Idaho.
Look at the access panel outside, now go inside and imagine where the back would have to be.
Panel may be screwed on, under the fridge, in a cabinet behind a thin panel.
Under kitchen counter?
The valves you seek are on the back of the water heater.
Old 01-12-2016, 06:25 PM   #4
Thank ya'll for the welcome and suggestions
Old 01-20-2016, 05:45 PM   #5
RKNOLA's Avatar
Sorry can't help you with your question, but I wanted to welcome you to the forum from another Louisiana resident!
Good Luck.
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 01-20-2016, 05:59 PM   #6
Members
Tommy Joann's Avatar
There should be an accessible door in the rear or side closest to your water heater access on the outside of your RV. There will be the valve location as well as the water filter.
2018 Salem 28RLDS Showstopper Package
2015 Chevy Silverado Crew Cab LT Sport
Husky Centerline WDH
Tommy Joann is offline   Reply With Quote
Old 01-20-2016, 06:05 PM   #7
Platokidd's Avatar
Welcome from the home of the Stanley Cup
power panel
Hot water bypass on back of tank, if it has one. You may be able to get at it from the outside storage area. Maybe a wall board you can take down. Or inside the unit under here. Try looking under the bed for access.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 01-22-2016, 12:14 PM   #8
Thanks for all the help! I did have to unscrew a panel in the front left corner storage to access the bypass valve. Is that where the breakers are in that lower console by the battery disconnect? While I'm asking that question, when I am set up for camping and plugged up to 30 amp power, should I push the battery knob in?
Old 01-22-2016, 02:38 PM   #9
Ford Idaho's Avatar
I do not disconnect the battery during camping season.
Battery must be connected for the breakaway to work, I would dislike it if I forgot to reconnect before hitting the road.
