Old 11-19-2015, 12:33 PM   #1
Greetings from largo florida
Hi my name is Dave and im new to the rv world.I bought a 2002 chevy sunseeker le .I Need some help with the grey water tank .If anybody has this model i would appreciate a picture of the grey water tank outlet at the tail pipe because mine is broken off.
MRMACH1 is offline   Reply With Quote
Old 11-19-2015, 06:19 PM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
Welcome to the forum and the world of RVing. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 11-20-2015, 08:42 AM   #3
Welcome from Wisconsin.
Old 11-20-2015, 09:13 AM   #4
AquaMan's Avatar
Welcome to the forum. If you can supply a picture of what you have existing now, we should be able to get a solution regardless of the exact model. The plumbing of the waste tanks is fairly simple in design.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
AquaMan is online now   Reply With Quote
Old 11-20-2015, 09:23 AM   #5
The gray water outlet is on the passenger side .Its broken off but what i cant figure out is that if i fix it the tail pipe is in the way which means i have to go over it or under it which really either way will restrict the flow
Old 11-21-2015, 09:36 AM   #6
RKNOLA's Avatar
Dave, Welcome to the forum and congrats on new RV. I grew up in Largo Fl. Close to 688 and Indian Rocks road area. Miss the beaches but not the traffic.
Rick
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 11-24-2015, 08:13 AM   #7
SilhouettePenny's Avatar
Welcome from Tennessee. If you can't post a pic of the damage, keep in mind that most waste water pipes are common thin wall PVC fittings available at Lowe's / Home Depot. Hacksaw a small 1" section from your rig, sketch a diagram on paper and spend some time in the isles at the home improvement store. PVC cleaner & glue, sandpaper and maybe some spray paint along with your new pipe, angle fitting and union. Lots of U-Tube videos on PVC methods. Good luck. Send us a picture of the finished project.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 11-24-2015, 09:14 AM   #8
thank i did what you said i will post pictures.i used white pvc and hose adapters.i will put a valve at the sewer outlet since this was just gray water.
