Old 07-23-2014, 12:58 AM   #1
23ss ROOster
Wags2237's Avatar
Talking Greetings from the Rocky Mountains
Glad to join you all in this thread. If I may ask.......just purchased a 2012 23ss ROO, up from a Coleman 1995 stony creek. Our tow vehicle is a 2002 gmc Yukon Denali, by passed the auto ride feature by adding fairly good shocks since auto ride compressor went out. What r your recommendations in regards to proper hitch size, sway bars, brake assist, etc in order to have the comfortable travels pulling this size ROO? A lot of mountain passes to climb. Likely considering replacing the Yukon with half ton or three quarter, gmc, Chevy, dodge, ford or tundra. Recommendations for upgraded vehicle? Thanks
Wags2237 is offline   Reply With Quote
Old 07-23-2014, 03:49 AM   #2
dcheatwood's Avatar
Welcome to our campfire. I'm a tundra driver and love the dependability and ride comfort but all manufacturers are making nice half tons now. This is a good resource to start your research. Good luck.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-23-2014, 04:06 AM   #3
rburns4147's Avatar
Welcome from Indiana!
Ron and Elizabeth
2014 Rockwood 8285-IKWS
2006 Ford F250 6.0 Diesel 4x4
rburns4147 is offline   Reply With Quote
Old 07-23-2014, 09:16 AM   #4
23ss ROOster
Wags2237's Avatar
Thanks dcheartwood. Agree, the Tundra has a lot to offer. Does the 5.7 have the hp for mountain driving, pulling? Any model years to stay away from? Thanks for your help.
Old 07-23-2014, 09:34 AM   #5
Welcome from the Front Range! I am pretty new here also, but not new to camping or towing. I would say consider how much towing vs daily driving the truck will be used for. Comfortable towing can make the trips more enjoyable, but if you are only towing rarely it might not make sense to get a 3/4 ton for limited use.
In the 1/2 ton (which is a misnomer at this point in time) range at altitude, you won't beat the Ecoboost F150 as an engine/trans combo, plus it is just fun to drive as a DD. If you get an F150, the max tow package is a really nice option to have. As dcheatwood stated, there are capable trucks from most of the manufacturers. No matter what you buy in 1/2 ton range make sure check the payload sticker on the truck you are looking at, as that is what is usually the first rating people surpass. And the sales staff often has no clue and just quotes the highest possible towing and payload ratings for that brand. Changing to some LT tires never seems to hurt anyone towing in the 1/2 ton range either.
madmaxmutt is offline   Reply With Quote
Old 07-23-2014, 09:42 AM   #6
Camper Less Camping
Cajun Po-Boy's Avatar
Name:	ImageUploadedByForest River Forums1406126445.675490.jpg
Welcome and you might as well buy the last truck you'll ever need for all the future camper upgrades you'll get into! LOL
Sent via Cajun Po-Boy's Tech Gear
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-23-2014, 09:47 AM   #7
23ss ROOster
Wags2237's Avatar
Hey mmm, thanks for the consideration. Yep, daily driving required more than the pulling of TT. Is the Eco boost a 6 cyc? Never owned Ford, just gmc and Toyota. Tell me more about the weight consideration and what to make sure of on this. Also, info on if I should consider wdh, sways, type of tire blocks, and even best way to level unit when backing into camping spot......hitch block, tire ramps, etc.
Current unit is 2012 23ssROO, tv is 2002 gmc Yukon Denali. Thanks for any ideas you may have. As you can tell, pretty much a newbie to the TT scene, moving up from pop up which was a breeze. Thanks, Greg
Old 07-23-2014, 09:55 AM   #8
Camper Less Camping
IMO, with you living/camping in higher elevations...the Ecoboost F150 will be a delight for your DD and towing needs...the turbos on the 6 cylinder will maintain your HP when climbing elevation vs normal gas engines.
Old 07-23-2014, 10:01 AM   #9
BamaBob's Avatar
Originally Posted by Wags2237 View Post
<SNIP> Likely considering replacing the Yukon with half ton or three quarter, gmc, Chevy, dodge, ford or tundra. Recommendations for upgraded vehicle? Thanks
First, welcome to the Forums from Huntsville, AL Wags!
Second, Recommendations on a truck? Hooooweee! This will touch off a religious war
I am of the Ford EcoBoost Faith, but there are members of all other truck Denominations on the Forums as well
One bit of advice: plan for the future! you have a Roo now, but if the upgrade bug bites you no telling where you will end up
(Take us for instance...we went from tents->Popup->TT & now our 5er )
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is online now   Reply With Quote
Old 07-23-2014, 10:04 AM   #10
BamaBob's Avatar
Originally Posted by Cajun Po-Boy View Post
Attachment 58763
You can use that beast as a TOAD when you make the "Final" upgrade to a Berkie?
mount
