Old 08-30-2015, 06:59 PM   #11
Removed whole L sectional and repaired frame. Was bent and the slider fabric was worn thru. Evidently its one piece?
Eqdawg87 is offline   Reply With Quote
Old 08-30-2015, 07:02 PM   #12
CAT-RN's Avatar
Ok. I took mine all apart and took it out the door. Put it all back together and put it in my son in laws man cave.
Russell
CAT-RN is offline   Reply With Quote
Old 08-30-2015, 07:07 PM   #13
L sectional slider was warped and fabric worn through. I guess its one piece to remove driver window? They rebuilt what I had instead of new replacement as was told new one would warp too in time.
Old 08-30-2015, 07:12 PM   #14
I noticed driver side front slide now is not sealing in the middle of pop out. Looks like the lower frame wasn't screwed in a straight line. Center is about 1.25'' out of alignment. It's a big slide out and the seal you can put your fingers behind when totally closed. Don't believe it's warped. Few kinks to get fixed.
