Old 07-15-2014, 05:19 AM   #1
Hello From Champaign, IL
We are new to the forums. Just bought a new to us 2005 Palamino Stampede 23' TT. We are upgrading from a pop-up and are pretty excited for our next camping trip in August. Now just need to go meet my aunt halfway between here and Upper Michigan! We are new to TT's, so anyone have any helpful tips or suggestions? Never have had to deal with fresh, gray, or black water tanks or systems.
Tank178 is offline   Reply With Quote
Old 07-15-2014, 05:30 AM   #2
Welcome! I too stepped up from a pop up, best thing I ever did.
Tip#1. Dump Black water first! Then the grey water will wash away anything nasty!
#2. Consider everything you put in the camper weight wise, Extra weight means less mpg, we often buy groceries once we arrive at our destination.
#3. Get a good light weight rug, or two, non of the old astro turf left overs, get the plastic folding ones!
2010 Surveyor 28 BH
2007 Chevy Silverado Classic
4.8 with Bully Dog Gas Tuner and 3.73 gears
Super Coop is offline   Reply With Quote
Old 07-15-2014, 05:49 AM   #3
rburns4147's Avatar
Welcome to the forum from Indiana and congrats on the upgrade! You should have many pleasant memories ahead.
Handling your holding tanks is not really hard but here are a couple of tips. Before you use your black tank, be sure to put some water in it. Some suggest putting about a third of a tank to start with. The idea is to have enough water in the bottom so that when you flush down the solids they do not clump on the bottom and form a concrete pyramid.
As you use the gray tank, remember that you are not at home. If you are not careful you can easily fill up your gray tank in a couple of days. Take navy showers (wet down, turn off water, soap up, turn on water to rinse) and use minimal water for washing hands and dishes. If you are staying at a campsite for an extended period of time, do some of those tasks at the shower house. After a couple of trips you will get a feel of how long your gray tank will last.
Always wipe down your dishes before you wash them. You want to keep as many solids as possible out of the gray tank. For short trips you can use paper plates, but for very long trips, you have to keep buying the silly things.
When you dump the tanks, hook up your sewer hose and dump the black first then the gray. That will clean out your hose.
If you camp at a place with sewer hookups, do not leave the black valve open to the sewer. If you do you will get that pile of solids below the toilet that won't come out. Let the black tank fill up (or nearly so) and dump periodically. Follow with a gray dump to clean out the hose.
Good luck and remember that there are many ways to accomplish the same thing so don't worry about "getting it right." As you use your camper and have questions, this is a great forum for information.
Ron and Elizabeth
2014 Rockwood 8285-IKWS
2006 Ford F250 6.0 Diesel 4x4
rburns4147 is offline   Reply With Quote
