Old 04-18-2011, 06:12 PM   #1
Ace Barker's Avatar
Hello from Georgia
Hey folks. I'm new here and I'm excited to buy my first RV. I'm trying to decide between a Palomino 273 and a Rockwood 2702SS. My tow vehicle is an 06 Tundra 4.7. Any in site would be much appreciated. I look forward to hanging out here.
Ace Barker is offline   Reply With Quote
Old 04-19-2011, 07:35 AM   #2
Glenn5995's Avatar
to the forum!
We would need more information about your Tundra to give an assessment, such as 4X2 or 4X4, reg cab or ext cab, etc?
Most sources list the MAXIMUM towing capacity for a 2006 4.7 Tundra as 6800 lbs, although Trailer Life lists the max at 7100. I don't know if your Tundra has the maximum capacity or not, but even at maximum capacity, either of those trailers will have you at or over your tow rating. The Palomino has a dry weight of 5252 and the Rockwood is 5053. Those weights are without optional equipment, propane or batteries. Realistically you are looking at 5400 to 5600 lbs before you even start loading your equipment and supplies. Then add the weight of a good weight distributing/sway control hitch, passengers in the vehicle and you most assuredly will be at or over the capacity of a Tundra with the maximum capacity tow package, your capacity may be less.
I personally don't believe you will be happy. I think you need to consider lighter trailers or upgrade your tow vehicle.
Please don't be discouraged. Camping is a wonderful experience and it is good to ask questions before you buy. So many do it the other way and end up with too much trailer and regret it. I commend you for asking first, but I honestly think either of those trailers will be too much.
Glenn
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
Old 04-19-2011, 08:29 AM   #3
brentnrobin's Avatar
to the forum!!!
2010 Wildwood 22FBCE
2010 Dodge Ram 1500 4x4 5.7L Hemi
Equal-i-zer 1000/10,000lb Hitch
Tekonsha Prodigy P2 Brake Control
brentnrobin is offline   Reply With Quote
Old 04-19-2011, 08:54 AM   #4
Ace Barker's Avatar
Thanks for the info Glenn. My truck is a 4x4 4-door. The tow capacity is listed as 6500. I figured it would be close to max.
Old 04-19-2011, 09:02 AM   #5
dretired's Avatar
Do the research ..
Get all the data you can before you purchase.. you will be glad that you did.. YOU dont want to overload your tow vehicle .. or trailer..TOO DANGEROUS.!!
dretired is offline   Reply With Quote
