Originally Posted by Rbare31
It’s my first RV but I grew up camping in a slide in truck camper. Many memories of lookin out over the cab window. Lol
Good deal. The reason I asked was that I usually provide the following to newer RV'ers who may find the following helpful. Maybe this can help you too.
The below is a copy and paste of useful information, and I usually recommend it to those just starting out. Some of it, you may already know, or may not be applicable to your particular RV. You will be able to filter out what pertains to your situation or not. I would suggest you read the electric threads and energy management first, and then the converter thread. This will help explain your different electrical systems of your RV, and how they operate...as well as what the converter does. The very first link will explain what operates off what system.
You can just peruse at your leisure as you get to know your RV:
Basic electric:
Basic RV Electricity - RV Information (RV Maintenance)
RV Electric
Your very important converter:
RV Converters and Amp Draw - RV Information (RV Maintenance)
Installing a dedicated 30 amp RV outlet at home (Make sure you understand it's 120 volts ONLY):
http://www.forestriverforums.com/for...tml#post231880
Suburban water heater (if applicable to your RV):
http://www.forestriverforums.com/for...tml#post327988
http://www.forestriverforums.com/for...ml#post1527599
Water Heater bypass/crossover valves:
http://www.forestriverforums.com/for...st-103381.html
And the newest additions to help understand what constitutes a true full cylinder in refilling vs exchanging propane cylinders... as well as how the automatic propane changeover regulator works:
http://www.forestriverforums.com/for...ng-133760.html
http://www.forestriverforums.com/for...ml#post1649595
Inverters and residential refrigerators in RV's:
http://rveducation101.com/articles/rvinverters.pdf
Bobby
