Originally Posted by metalmike57
50 amp to 30amp...why?....is there sites you go to only have 50amp?
No, most have both but the 30 Amp gets used more and that is hard on the blades inside of the receptacle and if one is broken it will not work as it should IF it works at all.
In the event this happens you can just switch from 30 to 50 which is easier than moving to another spot and way faster than waiting on someone to repair the broken one.
I have also read where some CG's have two units on one power box, if someone were there ahead of you and using the 30 it would be no problem for you to use the 50.
