Old 11-05-2015, 10:37 PM   #1
familytherapy's Avatar
Hello from Stallings, NC!
My wife and I just purchased a '12 30QBSS. Only been out in it once, but planning another next weekend before winterizing it. Having a great time with it so far.
2012 Forest River Salem 30QBSS
TV - 2015 Dodge Ram Big Horn Hemi
familytherapy is offline   Reply With Quote
Old 11-05-2015, 11:01 PM   #2
Welcome from just up the road in Concord, NC
What are you doing to winterize?
Old 11-05-2015, 11:46 PM   #3
asquared's Avatar
Welcome to the forums from Mebane, NC
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 11-06-2015, 07:57 AM   #4
I'm still learning what all needs to be done to winterize, but after our trip next weekend, the plan is to drain all the tanks and water heater and flush the antifreeze through the system. Other than bypassing the water heater and draining it, is there anything else that should be done? Thanks!
Old 11-06-2015, 08:48 AM   #5
Welcome from Waxhaw! We just got ours a couple weeks ago and we're going back out this weekend. I love your login name too!
2016 Apex 300BHS
TV: 2005 Silverado Z71, 4x4 lowered and re-geared
ApexBunk is offline   Reply With Quote
Old 11-06-2015, 09:00 AM   #6
Platokidd's Avatar
Welcome to the forum from the top side land of Lincoln
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 11-06-2015, 09:08 AM   #7
Platokidd's Avatar
Damprid.
For years we never had a problem with mice. Last year and this fall we did.
Freshcab repellent for mice. And a few mouse traps.
Bounce dryer sheets , use the whole (big) box
Im adding this to mine this year / Victor Mini PestChaser Night Light Rodent Repellers
mothballs in outside storage.
Steel-wool in hole openings where mice can get in
Drain your low point drains.
Remove all food
leave the fridge open
nights of camping
Seasonal
Old 11-07-2015, 11:18 AM   #8
Major's Avatar
Wow! I grew up about a mile or so from Stallings!
As far as winterizing... where you live it is not like you get really, really cold there. You might want to just drain the water heater, blow compressed air through all the lines one-at-a-time with each faucet open, open the low point drains and blow air, and that is it.
I have used this method on several RV's over the last ten years or so with no issues. I just don't like having to deal with the antifreeze stuff anymore.
Anyway... enjoy the RV!
Doug and Becky Ridgeway
2014 Blue Ridge 3600RS
2014 Ford F-350 CC 4X4 DRW 6.7 PSD
Troy, NC
Major is offline   Reply With Quote
Old 11-07-2015, 11:44 AM   #9
Hello from Haywood Co. NC, in the Smokies....
elynnkelley is offline   Reply With Quote
Old 11-08-2015, 01:47 AM   #10
asquared's Avatar
For winterizing, I use the pink stuff but many use the air compressor method, just make sure to keep the psi low enough not to damage pipes (I think it's 40 psi or somewhere around that. Do not forget to the outside shower when winterizing (if you have one). I also do the bounce dryer sheets and Clorox wipes on countertops and food cabinets before locking it up. This will kill the food smell. I leave an open bottle of peppermint oil with a piece of gauze sticking out of it in the trailer. Knock on wood never had a rodent issue yet. I also take out anything food related and all soaps, shampoos, toothpastes, meds etc that stay in it during season. These things can have attractive odors and done will change their texture if they freeze. Also make sure you empty your fresh tank and grey tank. I put pink stuff in my black tank as it should never sit empty. Make sure you drain your hot water heater and then bypass it. You should only need 1-2 bottles of the antifreeze.
2014 Sabre 34REQS-6
