Old 08-03-2016, 08:49 AM   #1
Red face Hello from WI, Looking for hot water heater help
My hot water went out and I am looking for help on how to get it out and replace it.
Mrsl is offline   Reply With Quote
Old 08-03-2016, 02:15 PM   #2
Head Rambler
Welcome.
Exactly what happened to it?
Can you give us the make and model of it?
A picture of it would help as well.
The make and model of the RV would help too.
The basic things you'll need to do;
Turn off all power including the 12 volt.
Turn off and drain the water from it.
Remove and access doors or panels inside the RV so you can access the back of it.
Remove the outside access door so you can remove the mounting screws around the flange.
Disconnect the plumbing at the back of the unit.
Disconnect the 120 volt and 12 volt power going to the unit.
Remove any mounting screws inside and out.
At that point you should be able to remove the unit from the RV. You may have to gently pry the caulking loose from the sidewall to get it out.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-03-2016, 02:17 PM   #3
Head Rambler
Having said all that, unless the vessel has sprung a leak, most anything else can be repaired without removing the unit.
Gotta go campin!
Old 08-03-2016, 02:32 PM   #4
Georgia Frog Rally 2017
aceinspp's Avatar
Welcome to the forum. As mentioned would help with type of camper and what type water heater. You may have burned out the heating element on the electric side. Have you tried using the gas side if so equip and does it work? Any other info you can provide will help. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
heater, hot water, water, water heater
