Old 08-12-2016, 06:21 PM   #1
Help! New Trailer Owners...Our slide out won't come out
Please help, we are camping and put slideout is acting crazy...one side seems to be sliding fine and the other side not so much...we have checked for blockage but can't find anything. We have had the trailer only a month and have gone one a couple of trips no problem. We are at a full hookups site
Haley2928 is offline   Reply With Quote
Old 08-12-2016, 06:31 PM   #2
Sorry to hear about your problems. I don't have a lot of experience with slides. I had a problem with a fuse that blew out on our Salem 27RKSS. Ended up having to move it manually. Can you see if the motor is running and the track is engaged? Also check to see if you have a cotter pin. Mine wouldn't work when I took it out.
Oithumper is offline   Reply With Quote
Old 08-12-2016, 06:53 PM   #3
Would help to know what kind of trailer and slide you have--electric motor, hydraulic, cable, rack, or ?
"Retirement is the best job I ever had!"
2016 Rockwood Signature Ultra Lite 8244WS 5th Wheel; 2015 Ram 2500 4x4 CC-SB 6.7L CTD
Sold: 2012 Rockwood Mini Lite 2109S
fanrgs is offline   Reply With Quote
Old 08-12-2016, 07:53 PM   #4
Thank you for the info, we have a wildwoodx-lite. It's electric...looks like a zipper. We were able to get it out by pushing on one side to keep it even...one side seems to be moving faster than the other causing it to bind.
Old 08-12-2016, 08:08 PM   #5
If it's a Schwintek, these may help you. There's some duplication in them.
If you need to get to the controller box, it's often placed behind a "fake" cabinet door. Look for a door with 2 hinges on one side and a hinge, instead of a knob, on the other. I've attached a pic of mine (the door with no knob on the bottom left). Remove the screws from the 3rd hinge and swing it open.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
slide, slide out, trailer
