Old 06-29-2019, 12:43 AM   #1
Princess Kelea
Princess Kelea's Avatar
Help Please! (Shore Power Cord)
This unit did not come with the power cord that may have been included when new. I'm trying to figure out which power cord I would need. The nearest Camping World is almost 2 hours away and from the pix on the website I cannot ascertain what I need.
I do have an adapter that goes from 30a to 15a but from what I've read that will not be sufficient to run the ducted A/C on this unit.
I am attaching pix of the Furrion 30A 125V (from what I can see from research this is a "marine" connection) that's installed on the unit and the pigtail adapter I have which I'm running on an extension cord to the garage for now.
We just purchased the Champion 7500 RV generator with remote and wheels to use when we're camping in the forest. It might be overkill for what we need but the price was great and I can start it from 80' away. Plus it's on wheels. Thanks for reading, sorry to be such a newbie, this is our first travel trailer.
PS: I think I added the RV to our garage. I'm not sure how to post except for here and I posted a reply to my garage entry.
Yep, I'm new! Thanks for having us!
ID:	208472   Click image for larger version
ID:	208473   Click image for larger version
ID:	208474   Click image for larger version
Princess Kelea is offline   Reply With Quote
Old 06-29-2019, 01:08 AM   #2
wmtire's Avatar
Howdy and welcome aboard. Electrical connections are best referred to by their "NEMA" assignments.
What you want is a shore power cord with a NEMA L5-30R end to connect to the RV and the other end to be a NEMA TT-30P to connect to the shore power outlet. The R and P at the end of the designation indicates whether its a Receptacle (female end) or Plug (male end)
Like this one on Amazon as just an example:
https://www.amazon.com/Weekender-Foo...omotive&sr=1-4
2011 Flagstaff 831 RLBSS
Old 06-29-2019, 01:11 AM   #3
wmtire's Avatar
Since you stated you were new, this thread may be of help also, as it's aimed at those in your situation (which we all were at one time):
http://www.forestriverforums.com/for...ts-157524.html
Old 06-29-2019, 01:12 AM   #4
bikendan's Avatar
Welcome to FRF!
Please post year, make and model of RV or put that info in your profile.
That way our members can more helpful.
Old 06-29-2019, 11:47 AM   #5
Princess Kelea
WOW! Thank you for that excellent graphic and your reply. Truly appreciate the response and help. Looking forward to helping someone else one day!
Kelea.
2015 Salem Hemisphere Lite 232IS
2007 Ford F-350 4x4 Diesel Super Duty
Jesus Saves!
Old 06-29-2019, 12:42 PM   #6
Princess Kelea
Originally Posted by bikendan View Post
Welcome to FRF!
I thought I did that - but I was in the "garage" - hopefully I've got it fixed now. Thank you.
Jesus Saves!
Old 06-29-2019, 01:48 PM   #7
The twist-lock end on the side of your camper is a standard configuration and is available from a few different well-known brands and some unknown offshore brands. Don't know about Conntek or Furrion, but on the Park Power/Marinco cord, you can get a collar that threads onto the power inlet or is 1/8 turn. We have the 1/8 turn and have had the threaded one in the past. I like the 1/8 turn much better.
The cords can be found on the internet from RV parts vendors or ebay or Amazon. Pays to shop around. You can also find them on CL sometimes. Don't buy a used one if the plug blades are pitted and dirty.
It's not a good idea to run an AC unit on 15 amps, even if nothing else is running. AC units draw around 12-15 amps depending on make & model. A converter will draw at least a few amps. Some will claim it's not an issue, but if you want to shorten the life of an AC unit or cause a cord's plug or connector to melt down, you can try it and find out what happens. New AC units are not cheap.
FWIW, when buying shore power cords or adapters, look to see if they're UL listed. If not, the quality of internal parts is unknown and could cause a poor connection. Unlike just about everything else electrical in this world, cords & adapters aren't required to be UL listed.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 07-02-2019, 07:55 PM   #8
rlh1957's Avatar
Be aware and fearful... just because someone is a licensed electrician they don't all seem to know an 30Amp RV plug is not 250V but always 125V for RV's.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
