Old 11-14-2012, 12:35 PM   #11
sewdarnhot's Avatar
Yah.thats the type but no gas is getting into the line.
No turkey yet but gonna go get one on Sat!! Thank you
KimberlyAnn & Wes & 4 little ones
2006 Wildwood 37'
New to RV's but love to camp
sewdarnhot is offline   Reply With Quote
Old 11-14-2012, 12:39 PM   #12
Do you have gas to the cook top? Is there a valve around the water heater that needs to be turned on?
Read pm.
Old 11-14-2012, 12:53 PM   #13
sewdarnhot's Avatar
Yes. Gas on stove works. Do not see any other valves. Gonna get daughter off to school and ill be back to check more. I pmed you back
2006 Wildwood 37'
Old 11-14-2012, 01:42 PM   #14
All I can suggest is make sure the knob is on Pilot and keep pressing and holding the red button with a flame to the pilot. It takes quite a while to bleed the air out of the line.
Old 11-14-2012, 02:36 PM   #15
Iggy's Avatar
sewdarnhot
Turn the black knob on the top to pilot and press that black knob down.
This will start releasing the propane. After a few seconds while still pushing down light the pilot light inside the hole in lower right.
Remember you are still holding down the black knob until the pilot light stays on by itself.
The flame should increase inside that chamber in the lower right where the pilot light is. Do not look directly into the hole as the flame may come out 1st when it is lit.
This may take 2 people to get it started the first time.
The red button is the reset button in case it over heated.
Hope this helps a little
Old 11-14-2012, 02:57 PM   #16
Iggy is correct on holding the black knob down. I was thinking of the red button that locked the knob. Wrong type of heater. Sorry about that.
Old 11-14-2012, 03:52 PM   #17
Iggy's Avatar
If you tried all we have suggested and you still don't smell any gas then I would think the regulator is bad or the orifice is clogged.
You also must heat up the thermo couple enogh to keep the gas going.
It may take a minute or two being it is cold.
That is the small bulb at the end of the tube inside the chamber.
Old 11-14-2012, 05:27 PM   #18
sewdarnhot, you need to delete some pm's as you've reached the limit.
Old 11-14-2012, 06:02 PM   #19
From what I understand, they finally got the water heater lit and everything is now working. Thanks to Iggy for his correct instructions. Thanks Iggy!
Old 11-14-2012, 10:25 PM   #20
sewdarnhot's Avatar
Hi, Sorry I went MIA.
Has mom duties to take care of.
Yes, Thank you everyone for all your help! We were trying to light the gas orifice in Iggys photo. Sad thing was the video I was watching the other day showed it but I was not able o watch it to the very end when it showed the actual place for the pilot to be lit.
Hot water working great. able to take a nice shower and do dishes. It is turning on and regulating as needed. I wonder how much gas it uses and if I should shut it off durring the day or is it really worth being on/off and restarting. Will it use a lot of gas in idle (When not using the water)??
2006 Wildwood 37'
