Having a problem with my rear jacks they are electric
No in line fuse that I could find.. Anyone know where it might be located.
Trailer is a 2012 27rkss wildwood..
Thanks for any help..
follow positive battery cable check resettable circuit breakers .
I have an inline fuse for jacks with a separate wire coming from battery .
Did you check the control center for fuses ?
No separate wire from battery and all the fuses I checked we're good..
I did see a box on frame near battery but no fuses in it..
Any other info.. And thank u for the welcome..
Which is why you need to see if you have power at the switch to see if you have a defective motor .
IF you do not have a digital volt ohm meter than now would be the time to buy one for your camper and leave it in there .
I have power at the switch so I will assume I have a bad motor.. But how do I manually crack the jacks down because they don't move.. Do I have to disconnect something first?? Any ideas will help.. Thanks
