There is usually a couple of outlets with the actual GFCI. Find them and push in the test and reset buttons. same as in your house. If no power is getting to it, check the circuit breaker. If the circuit breaker is fine, unless youare very comfortable working on electrical stuff, get the dealer to check it out. The GFCI outlet may be bad.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
