Old 08-31-2013, 02:33 PM   #1
Hi to all out there
Just joined. I have just purchased a Forest River Surveyor Select TT. First outing in hot weather and the Dometic Thermostat refuses to work so no AC. What a bummer!
Rmstack is offline   Reply With Quote
Old 08-31-2013, 02:37 PM   #2
Twisty's Avatar
Welcome!
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 08-31-2013, 02:54 PM   #3
Phat Phrog Stunt Crew
awwall's Avatar
The new Dometic therms can be tricky. I had to read the manual twice to understand it....
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 08-31-2013, 03:08 PM   #4
Welcome to Forest River Forums!
Does your thermostat looks like this (in black or white)?
What have you tried? What are the symptoms? Do you see anything on the screen?
Old 08-31-2013, 09:47 PM   #5
RReply
Attachment 38958
My thermometer does not look like this as shown. On the left of the LCD is: Fan, Cool, Heat
On the right of the LCD is only a "+" and "-"
Below the LCD is "Mode"
More than likely it is a newer model as my unit is a 2014 that arrived in August. I had ordered it in
early June.
Old 08-31-2013, 09:52 PM   #6
Old 08-31-2013, 10:19 PM   #7
awwall's Avatar
Here is operating manual if this will help...
Thermostat-SingleZoneDigital-Dometic-OperatingInstructions.pdf
FROG Member
Old 08-31-2013, 10:21 PM   #8
Have you tried to push the mode button? Bring the LED light down to AC the + - keys are the temp.
2012 Coachmen Freedom Express Deep Slide 270FLDS
2012 Ford F150 Eco Boost
Andersen WDH
uncle46 is offline   Reply With Quote
Old 08-31-2013, 10:43 PM   #9
Batts-toy's Avatar
I found that mine (appears to be the same thermostat) only requires some patience I thought mine wasn't working until I had it on and got side tracked on something else and it finally started up. Turned out it needed a little time to think it over before starting up.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 08-31-2013, 10:45 PM   #10
Batts-toy's Avatar
clarification- when I said looks the same I was referring to the one in awwall's link not the picture Barry posted.
