Old 02-25-2013, 08:42 AM   #21
Senior member
geodavis's Avatar
Welcome on your new tt. Know of hoc use to live in oak lawn. Hardest part is waiting. Welcome to the forum.
2012 Salem 27rls TT
2006 Dodge Ram Big horn 5.7 v 8
2012 camped 32 days
2013 so far 48 days
geodavis is offline   Reply With Quote
Old 02-25-2013, 09:39 PM   #22
Terier's Avatar
Originally Posted by DAISY BOYKIN View Post
At each and every campground hookup, after hooking your hose to the campground water connection and if you are using a external filter , always flush the filter and hose and the piping of the RV park. Do this before you hook the hose to your camper!!! You will be surprised at what comes out of the campground water connection sometimes.
If you are using an external filter at the CG connection, especially if it is a brand new filter, always flush the loose charcoal that is in the filter before connecting to camper.
I always flush my hose, filter, regulator just in case something has crawled into the hose or filter while in storage. Again, you never know if a small mouse has crawled in to the hose!!
When I break camp and disconnect the hose, I drain the hose, coil it up, SCREW THE TWO ENDS TOGETHER , this will help insure nothing can crawl into your hose (roaches, mouse, scorpion) while stored!
Good luck
Great suggestions! After encountering a bit of charcoal water after connecting a new filter I learned to flush it out before connecting it to the trailer.
Terier is online now   Reply With Quote
Old 03-14-2013, 01:45 PM   #23
I just bought a new travel trailer. i have a question about the water. When you fill your tt up at a camp site that has water do you have to leave the pump running all the time to get water out or do you just run it for water pressure.
cblaze88 is offline   Reply With Quote
Old 03-14-2013, 01:51 PM   #24
TURBS's Avatar
You don't fill your camper up at a camp ground that has water available.
You instead hook up to the city water connection and when you do have a city water connection you don't use the pump.
Only time you use water pump is when you do fill up you fw tank and go camping where there's no water available.
Turbs
Old 03-14-2013, 02:01 PM   #25
Thank you
Old 03-14-2013, 02:10 PM   #26
TURBS's Avatar
Thank you
Your very welcome.
Turbs
Old 03-14-2013, 02:29 PM   #27
Got one more question, next to the pump switch is a another switch that says HTR is that the hot water heater.
Old 03-14-2013, 02:37 PM   #28
TURBS's Avatar
Is it a lighted switch ?
Or is there a light next to it?
Please be reminded not to turn wh switch on unless wh tank is full of water.
Turbs
Old 03-14-2013, 03:27 PM   #29
no its not lighted its it the box with all the other switches, like the awning button, slideout, it is on the bottom next to the pump button
Old 03-14-2013, 03:41 PM   #30
TURBS's Avatar
Pics ?
What year make am d model is this?
