09-16-2017, 02:46 PM
Kitchen faucet not working
Hello all. I'm new to the rving so wife and I purchased a 2018 Flagstaff V-LITE model 30wfkss.
Have water everywhere else but the kitchen sink. I've checked for shut off valves and kinked lines. Even cleaned out the screens on the sprayer. Only thing in my mind is"maybe they didn't hook the lines to the water inlets." Doesn't work on potable or city connection so I'm at a loss
Thanks for any advice.
09-16-2017, 02:54 PM
I've read here that SOME of these things have a screen/filter where they connect to plumbing under the cabinet. No hot or cold either?
09-16-2017, 03:28 PM
Unscrew the screen on the end of the faucet spout. Most likely needs cleaning. A common issue.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
09-16-2017, 03:30 PM
I assumed that's what he meant when he said "Even cleaned out the screens on the sprayer."
09-16-2017, 03:31 PM
Nope... Neither one works. At the two Rivers RV park in Nashville with a camping world right next door. Bought mine from a camping world in Missouri and this one doesn't even seem interested in helping...😕
09-16-2017, 03:37 PM
I did, but even then with the head of the sprayer off there was no flow.
I also disconnected the lines leading to the faucet with no luck.
09-16-2017, 04:27 PM
Senior Member - Retired
Based on your picture I believe we have the identical model kitchen faucet.
Mine clogged up once and cleaning out the spray filter did no good. Also checked the flexible plastic tubing under the sink which connects to the spray nozzle which also did no good. Finally disassembled the water selection handle and removed the internal cartridge. Found debris clogging what are extremely small openings for the passage of water. Cleaned everything out, put it back together and faucet worked perfectly. Did this a year ago and so far no repeat problems. If your faucet model is the same as mine you should be able to locate a small set screw on the water section handle which will enable you to remove the handle and gain access to the internal cartridge. Good luck to you!
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
09-16-2017, 05:32 PM
Thanks!! Will try this...
09-17-2017, 09:34 PM
Well, I'm an idiot 😖... I've been frustrated with this faucet for 2 days now and out of the blue the wife gets it to work... Apparently, you need to pull the handle out and then rotate it back and forth...
09-17-2017, 09:37 PM
Thanks for reporting back with your findings. Hopefully, this exercise will help another member down the track.
09-20-2017, 12:27 PM
Originally Posted by Gun guy
Well, I'm an idiot [emoji37]... I've been frustrated with this faucet for 2 days now and out of the blue the wife gets it to work... Apparently, you need to pull the handle out and then rotate it back and forth...
If you don’t already you should use an inline water filter—Just my opinion
09-20-2017, 06:21 PM
Thanks! Will do that, it's all new to her and I so we're learning as we go... LOL
09-20-2017, 06:39 PM
EDIT... DELETED
Didn't read the last few posts.
Sorry.
09-28-2017, 01:30 AM
Well, I'm an idiot ... I've been frustrated with this faucet for 2 days now and out of the blue the wife gets it to work... Apparently, you need to pull the handle out and then rotate it back and forth...
Gun guy- just getting ready to tell you how it works when I saw this post. We did exactly the same thing when we got our new fiver home. Couldn't get the darn kitchen sink faucet to come on. Just like you. We actually had the dealer on the phone when we accidentally pushed it the right way and the water came on...
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
