Old 06-18-2015, 09:36 AM   #1
Leveling Jacks
When trying to level a motorhome using the automatic leveling jacks is it safe to have the tires completely off the ground. Will this harm the jacks?
Gorman is offline   Reply With Quote
Old 06-18-2015, 09:52 AM   #2
There are a couple things to watch for, don't lift the rear tires off the ground, you won't have any parking brake function , and if you fully extend the leveling rams they aren't as study to side movement, my opinion is try to keep all tires on ground, others will say its OK to lift fronts off ground.If you completely lift the MH you COULD! run the risk of buckling the rams over.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 06-18-2015, 10:38 AM   #3
Limey's Avatar
No don't do it. If needed place blocking under wheels so they are never off any surface.
Limey is offline   Reply With Quote
Old 06-18-2015, 01:37 PM   #4
Never lift wheels completely off of a surface albeit the ground or your leveling blocks...
Douglas Houston
Flower Mound,TX
1999 2500 Suburban
2013 WFKSS-30 V-Lite
2015 - 209 days
dhouston16 is offline   Reply With Quote
jacks, leveling
