03-04-2019, 10:48 AM
Locked Out of my Rig
I have 2000 FR cardinal fifth wheel. I had my truck stolen with all my keys in it. To get new ones from mfg, I need the VIN. Is there a vin that can be seen without opening the door? My paperwork is inside.
The only identifying numbers i can see are on the OR RV certificate of compliance. Can these be used to get the vin?
03-04-2019, 10:56 AM
waybeck2018
Been there, done that minus the vehicle stolen. I have started taking photos of ALL vital auto/Travel Trailer VIN, license #, insurance info etc. It stays on the phone and is readily available in case of theft, or lockout. I also record my pistol serial numbers and any electronics this way. Helps law enforcement to have these things in the event of theft. You can bet they will ask you for it.
2012 F-250, 6.7 Super Duty Powerstroke; 2019 291 BR Primetime Tracer,
Days camped in 2018-61
Looking Forward to Completing This Map Soon !
03-04-2019, 10:58 AM
Call your local tax collector where you get your license plate. They will have the vin on the registration..
Can you help me by telling me where to find the VIN please?
03-04-2019, 11:01 AM
I don't have the license plate. I haven't registered in my name yet. I bought it from a lot.
03-04-2019, 11:05 AM
RV There Yet?
Your vin is usually on the frame somewhere. does your lock cylinder have any markings or numbers on it? a lot of times camper locks are keyed the same.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
03-04-2019, 11:12 AM
VIN should be on a small metal plate 3" X 2" near the hitch. It should also be on the title you were given when you bought it or the bill of sale.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-04-2019, 11:19 AM
The VIN is on the sticker on the side of the trailer. Listed with manufacture date and weight capacities.
03-04-2019, 11:35 AM
Hi,
Years ago, after a chilly hour or so helping a camping buddy find a way to jimmy open a vulnerable trailer window, I hid a spare set of keys on the outside of my fiver.
Actually found them convenient to use several times when I went to the storage yard without my regular keys, saving me a trip back home.
FWIW.
Rich Phillips
03-04-2019, 11:42 AM
Call the lot.. they must have it.
03-04-2019, 11:43 AM
There is a possibility that your door lock is one of the common key models. If you have any local friends with an RV you might ask to try their key
TST Tire Monitors
2 100W solar panels
It’s a 2000 model. I don’t think they did that 19 years ago...
03-04-2019, 11:45 AM
My suggestion would be to call the lot where you bought the trailer. They should have a record of the VIN if you can't find it on the trailer.
If not, you're probably going to have to call a locksmith. Did the vehicle come with any type of roadside assistance? Usually, a lockout service is included.
2015 Dynamax REV 24TB class C
03-04-2019, 01:50 PM
You are correct. The white factory UVW weight sticker will be inside the trailer, on the inside of a cabinet door.
03-04-2019, 02:09 PM
your insurance company will have a copy of the VIN
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
03-04-2019, 09:20 PM
As a previous comment I would call a locksmith.
03-04-2019, 09:57 PM
Call a locksmith, have him make a key then get some duplicates then put them in one of your outside storage compartments. I have used mine several times and i am a locksmith. Good luck..
2012 Ram 3500
2016 Silverback 33IK
03-04-2019, 10:06 PM
Even though it is not a cardinal my Wildcat has it stamped on the bracket where the pin box is mounted.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
03-05-2019, 12:55 AM
bloodybill
hello and welcome
03-06-2019, 08:12 AM
Mopar Guy
forest river marked fivers in the following places since 1990
Stamped into the "Pin Box" frame. (Not the adjustable sleeve)
Stamped into a tag which is mounted to the "Pin Box" frame.
Stamped in the entrance door frame (not the door) just above the striker plate. (Found when outside, facing the doorway, with the door open).
Stamped into a steel cross member in the lower front
Compartment (accessed from the front of the unit below the overhang i.e. the front jack leg area) on the driver's side.
Dave
2019 Grey Wolf 24JS- sold
1998 Holiday Rambler Imperial 41wds
