Hi, I have a 2011 Roo 21ss and had a problem with the electric slide out and wanted to use the manual one however searched every for it but couldn't find it. Have checked the motor and frame for the actuator. Just wondering 1) whether this model has a manual system to retract the slide 2) where it is located. Thanks Glen
I have a 2015 Roo 23SS and the manual slide piston is underneath the couch on the inside of the trailer. You may want to check the fuse for the slide. Mine has blown two so far. On my trailer the fuse is located under the frame within two feet of the battery. It should be a 30Amp
I noticed that in my trailer, a lot of things you need access to (water heater, water filter etc) are hidden by cabinet doors that have double hinges screwed into them. I took the screws out and replaced the hinge with my own latch. Your actuator could be hidden that way.
