01-11-2012, 12:32 PM
Microwave A/C problems
Have a 2005 Rockwood Roo 233. Had to replace my inverter/converter last month. Was not charging battery and not converting power over. I replaced the converter with a WF8955 MBA. Only difference in main board assembly was that the new one had an extra black wire piggy backed. The problem I am having now is that when I use the A/C and turn on the microwave (m/w) they both lose some power and then quit. The A/C works just fine without the m/w. The m/v on its own works but seems to lose some power. A cup of water will get hot. I took the m/v out and tried it in the house and it works just fine. All outlets are showing 120 volts. Any ideas? Thanks,
Pat
01-11-2012, 04:48 PM
Lou Amadio
I have a few questions before I make a suggestion.
Are you plugging directly into the house with the supplied camper power cord to a dedicated 30 or 50 AMP RV socket that is correctly wired to your house fuse box?
If you ARE:
Are you using an extension cord of any kind?
If NOT using a dedicated 30/50 AMP RV circuit:
Are you using a plug adapter to plug into a 110VAC (20 or 15 amp) house type outlet?
IF YOU ARE
Be aware that a 15 amp circuit WILL NOT run the Air Conditioner and almost any other piece AC equipment.
Be aware that a 20 amp circuit WILL NOT run the Air Conditioner (or heater0 and the microwave (or toaster/coffee maker) at the same time. It should run the air and the TV just fine however).
Also:
Are you running an extension cord OF ANY KIND.
IF SO
There is voltage reduction AND increased current usage based on the number of feet of extension cord. The HEAVIER the cable; the less power lost in the cable. A lawn type extension cord will most likely carry the AC load (but will get very hot) but never the microwave.
How you answer will determine where I think you should go to solve your problem.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
01-12-2012, 09:04 AM
Howdy, Thanks for your response. I am using an 20A outlet from the house and using a heavy duty extension cord and the campers power cord. I guess I never tried the microwave and A/C together at home before. We are going camping later this month and I will try it at a dedicated 30A circuit there. I guess i'll have to wait until then unless you think there might be something else.
01-12-2012, 04:05 PM
Lou Amadio
Nope, my money is now on low AC voltage due to line loss during power up of the microwave. If you buy a 120VAC plug in volt meter (cheap) you can actually watch that voltage drop below 90 volts when the AC compressor or Microwave fires up.
You are getting the full 120 VAC with low load, but try to pull a large bunch of amps through a heavy duty extension cord and the voltage loss in through the cord will cause the voltage to plummet.
A Voltage stabilizer like the one pictured will help by converting amps to volts to keep your line voltage up under heavy usage. The downside is that it increases amp draw from your source to provide the correct voltage at your camper.
Example:
Microwave Load 1200 watts (120 volts x 10 amps)
Air Conditioning Load 1200 watts (120 volts x 10 amps)
Load in camper: 2400 watts (120 volts x 20 amps)
Load at outlet 20 amps - circuit breaker can hold the load.
Line loss due to trying to cram 20 amps through that long skinny extension cord drops voltage to 100 volts.
Air Conditioner "lugs" and may burn itself up.
Microwave magnetron may not fire at all or might burn itself up.
Putting the stabilizer in the circuit:
The 100 volt condition puts the Franks into "High Boost" and boosts the voltage to 117 volts. Air Conditioner is happy; microwave is happy; Fuse panel NOT happy. The franks will consume an additional 4 amps to make that voltage and your house fuse will blow.
If you intend to continue using an extension cord get a high quality 30 amp one. Plug into a circuit rated at 30 amps. ALWAYS check voltage available at the outlet UNDER LOAD. Carry a power stabilizer in your bag of tricks for when your spot is at the end of the campground's circuit run and everyone is using their air conditioners.
I have been at campgrounds and was only getting 105 volts from the pedestal BEFORE I plugged in. My Franks gets unpacked and hooked up before the camper is.
I HIGHLY recommend a 30 amp rated extension cord to limit line loss.
01-12-2012, 04:06 PM
Lou Amadio
Oh, and as an aside. Most likely you burned up that converter from low voltage (brown out conditions).
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 583 |
| 91 members and 492 guests |
| 200smk, 4bnabird, 4runner freak, 64c10, B47, biketow, BJAY, BlakeB, bob34787, bob7794, boblee, booneandbuck, bush, cardinal4fun, cdbus, COcamper, Cowracer, csichoice, danred, DAREK.NIEUWSMA, datadr, davidjb, Derick441, dfrauhiger, DGrissom, dimurrrw, djorgensen3, dknight903, DonG, donn, dunnnc, Elidh, extremebike, fivecodys, fonzie, freedom 750, FreedomTracker, gimp425, Greywolfmn, Hatesreverse, herk7769, Hob, JAJ73, jmswms, Jo54, johnthecamper, jrb988, Juan14888, kathomas, KRS, kshep, Laura, lbrjet, ldmcmahan, leennp, Loui, lynnd, Mattpopp, mdoerner, merlin66043, mike1329, NO3putt, OffPavement, Old car, Old Jeeper, Papa Roo, pappcam, ParrotHead, photog, pmahoney, PrairieBoy, rburk015, RV Guy, Sahgie, sellis1053, shane1234, Smitty75, snipe, SpringerPop, Superchief, Tee, Terier, the.wilsons, thickie, Tom993, trudinator, twalk47, whj77372, Wildcatgps, windrider, Zama |
| Most users ever online was 1,025, Today at 01:04 PM. |
