Old 06-20-2015, 08:56 PM   #1
new a128 s owner
Getting too old to sleep on the ground so we picked up a 2012 a128 rockwood ,love the setup and the rest of this rig but : we found that the water tank had a crack in it and leaks . I haven't talked to the dealer we got it from yet (it was a consignment rig ), but does anyone have any experience with fixing these ,or is it a replacement issue ? The camper fits exactly what we were looking for and this issue is giving me a bad feeling .
spellcast1 is offline   Reply With Quote
Old 06-20-2015, 09:40 PM   #2
It is possible the tank can be repaired depending on how big and the location of the crack. The problem is these tanks are meant to expand and flex when they are full. That can lead to the repair failing. Especially if you are traveling with a full tank. Wether it's repaired by plastic welding or a patch it still ends up being a weak spot that can crack again when under pressure. If your going to be using this tank a lot it would be better to just replace it and then you would not have to worry about it failing again. With it being a consignment unit, the dealership may or may not flip the bill for this one. A lot of times consignment trailers are sold "as is". They may only repair issues that the previous owner was willing to pay for. If they did a prep or a systems check this issue should have been noted and brought to your attention. Contact them about this issue ASAP.
OneRoomShed Trailer Tech is offline   Reply With Quote
Old 06-21-2015, 10:30 AM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
Welcome to the forum. I agree with one room get back to the dealer ASAP. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
a128
