06-18-2016, 09:48 AM
New campers
Hello from Ks! Happy to be a family of new campers! Just purchased a 2016 Vibe 322QBS. We'll be staying close to home for a while. Just want to get a feel for it before we venture out. Looking to convert our 50 amp 220v hot tub line to a 50 amp 110v hook up to prep here at home. Ugh
Really looking forward to the "community" here on the site!
06-18-2016, 10:47 AM
Welcome! Make sure you get an electrician that knows RV electrical requirements!! I'm amazed at some of the stories about trained electricians that don't do RV power correctly.
Brian, Stacy, and the kids
2011 F-250 CCSB 6.7L PSD 4WD
2013 Palomino Solaire 269BHDSK
ProPride Hitch
06-18-2016, 11:22 AM
Georgia Rally Coordinator
Welcome to the forum.It would be a lot easier to do a 30amp hook up which will still run 1 ac. Unless you are not planing on sleeping a lot in it at home need not need 50amp. I have 30amp service to my 50 amp camper . Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
06-18-2016, 11:25 AM
I did not know that their was a difference between home 50 amp 0r 30 amp110- volt and rv 50 and 30 amp 110- volt please tell me
06-18-2016, 12:35 PM
The confusion that usually causes problems is that the RV power (for 50 amp) is a 220 volt hookup. That 220 volts is divided into two 110 volt legs. So, when you connect your RV to a 50 amp service, you are really connecting it to two 110 volt lines, NOT a single 220 volt line.
I'm sure others can explain it more elegantly, but that's the essential issue.
ProPride Hitch
06-18-2016, 05:33 PM
so tell me now about 30 amp rv how is that different then the house?
and someone is say that a electrician wont know this ?
06-18-2016, 08:22 PM
30 amp is just a larger capacity, single 110 volt service. Will not usually cause too much confusion because it is the same wiring setup as a normal household circuit (well, except for the heavier wire, higher capacity circuit breaker, and RV receptacle).
Also note, whether you have a 30 or 50 amp RV, a 30 amp circuit at home will get you so most of what you need (lights, AC, pre cool frig, etc).
ProPride Hitch
06-18-2016, 08:30 PM
And, yes, certified electricians have hooked up 50 amp RV outlets to deliver one leg of 220 volts instead of 2 legs of 110. Hasn't happened to me personally, but there are reports of it happening on this and other RV forums.
ProPride Hitch
06-18-2016, 08:51 PM
I go RV'ing not Camping
Congrats on your new trailer
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
06-18-2016, 09:24 PM
Retired
Welcome to the FRForum.
We had an electrician installed a RV outdoor elec box (50 & 30amp RV receptacles and 2 110V outlets all with GFI) so we can use the TT when it is parked at our house (purchased from ZORO.com). The TT is fully functional without using the LP. Great place to watch a BB game on a rainy day plus the grand-children love staying in it when they visit.
Happy Trails
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
06-18-2016, 10:22 PM
welcome to the forum, before you jump in and change the 50/220 at your house you need to read up on how the 50 amp service works for an RV. At the pedestal it is 220 (like your hot tub) however when you plug in with your 50 amp cord to the TT it splits the service into two 110 circuits with a common neutral. Check with a qualified electron that knows RVs to be certain
Retired Navy
2016 Flagstaff 26 FKWS
06-19-2016, 11:10 AM
Welcome from Wisconsin and congrats on your 2016 Vibe 322QBS.
06-20-2016, 10:26 PM
Thanks everyone! I will definitely get a sparktrician to take care of it as neither the hubby or I are knowledgeable enough to attempt it. Ha ha
