Old 08-09-2016, 12:14 AM   #1
New for us rpod182g
no clue what we're doing but excited about getting to know our new toy!
Not sure if it's user error or a pod problem but appreciate any advice on how to use fresh water. Filled tank, opened faucets, turned on pump (could hear it, let it run 10 minutes) but no water.
Acampbell is offline   Reply With Quote
Old 08-09-2016, 06:08 AM   #2
dlwilliams48's Avatar
Can't help with the water, but welcome to the forum.
Don & Mary (Don - retired Navy, AB4GR Ham Call)
2016 Forest River Surveyor 243RBS
2013 Ford F150 Ruby Red Super Crew Eco-boost
2017 - 5485 miles, 49 nights
2016 - 3005 miles, 34 nights
2014, 14, 15 - 11,614 miles, 125 nights
dlwilliams48 is offline   Reply With Quote
Old 08-09-2016, 08:03 PM   #3
Hi and congrats on the the Pod. Re: fresh water. The pump should only run until it reaches 40-50 psi, on a full tank 10 mins seems long ( I could be wrong). Have you tried with the city water hook up to help troubleshoot?
Sent from my SAMSUNG-SM-N910A using Tapatalk
richardhearn is offline   Reply With Quote
Old 08-09-2016, 08:18 PM   #4
SeaDog's Avatar
I would hook up to city and ensure all lines are full including the water heater, then disconnect from city water and try the pump again with faucets closed to see if it will build pressure.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 08-09-2016, 08:41 PM   #5
You say "new to us" rpod. It may be the pump is no good. Have you EVER seen it work?
If you've filled the lines via the city water connection, then with the faucet's closed, the pump should pressurize the lines and shut off within less than a minute (usually about 10 seconds). With the faucets open, you should have water essentially immediately.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 08-09-2016, 11:06 PM   #6
may have valves still in closed position on the pump itself. Sure you've got water?
todd172 is offline   Reply With Quote
Old 08-10-2016, 12:18 AM   #7
Yeah, his suction valves may be set for anti-freeze.
Acampbell: Attached is a general sketch of most RV systems; check the valve(s) on the suction side of your pump.
Old 08-10-2016, 01:00 AM   #8
Crookedread
crookedread's Avatar
When my trailer was new it would not prime just like yours. Look in the screw on filter right before the pump. I cleaned out small plastic construction junk and the pump primed and I had water. Just a thought!!
Crookedread
2016 Duramax
2011 Stealth 2312
crookedread is offline   Reply With Quote
Old 08-21-2016, 09:28 PM   #9
Thanks! We took the pump apart, cleaned out gunk and we're all set!!!
Old 08-21-2016, 11:02 PM   #10
Crookedread
Glad that worked! Have a great time out there!
Crookedread
2016 Duramax
2011 Stealth 2312
