08-29-2016, 08:21 AM
New here and need some help. Awning issue!!!
My wife and I just bought a used 2013 Xlr Hyper Lite 27hfs. There seems to be an issue with the automatic roll out awning. It works fine 1/2 to 3/4 of the way out, but if you try to fully extend it, it drops severely to the point you can't hardly walk under it and the door rubs pretty hard on the awning when opening. I didn't think it was much of an issue, but we went camping this past weekend and our friends have a fifth wheel with a very similar setup on their trailer. Theirs seems to work properly. It comes out and doesn't drop. My question is, is there any type of adjustment or something I can do to fix this problem?? The awning is a Dometic ae 915EH18.501U. Thanks in advance for any help!!
Scott
08-29-2016, 08:32 AM
awning issue
There is a hand nut that you tighten when you want to bring the outer end of the awning down on each end frame. Make sure those are loose when you retract the awning. Although I am not sure if the awning will retract if they are tightened. Never tried it.
08-29-2016, 08:53 AM
Georgia Rally Coordinator
Welcome to the forum. You might check the gas struts if equipped as they may be weak. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
08-29-2016, 10:59 AM
The nuts are loose. I'm not sure how to test the gas shocks to see if they are bad?!? They seem tight and I'm not able to raise the awning up by hand when it is fully extended. How can I upload a picture using a smart phone??
08-29-2016, 11:01 AM
Here is another picture
08-29-2016, 11:13 AM
In your first picture it looks to me like the awning fabric is coming loose at the top in the front. I would take a close look at this and see what is going on there.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
08-29-2016, 11:19 AM
Something may be binding/bent in the tracks on the side of the trailer. A rock or foreign matter may have gotten in there(at the bottom on the track). I have GS that could easily put something in there. Cheap check.
2017 Puma 297RLSS
08-29-2016, 11:25 AM
It's not coming loose. That's the door hitting the awning when it's open. I'm pretty sure the door is supposed to clear the awning when opened?!? I'd like to find a solution to fix this myself as I'm not sure what a dealer would charge but I'm sure it wouldn't be cheap!!!
08-29-2016, 11:33 AM
awning issue
If I extend my awning out all the way it creates a "valley" where the fabric meets the roll. It looks like yours does the same. So I back it up a little so the fabric rolls over the tube and there is no "valley" at the bottom. It also looks like your awning is mounted down on the wall. Could it be repositioned up to the top of the wall? That would give you more clearance over the door.
08-29-2016, 11:49 AM
Look at this picture....maybe your awning is not assembled correctly for your trailer.
http://www.rvwholesalers.com/images/...061690/005.jpg
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
08-29-2016, 12:16 PM
The slope of the awning looks about right. I'm not sure if there's anything that can be done about getting it to raise more than it already does. The top anchor track looks like it's pretty close to the top of the RV on the door end, so raising it up on the RV looks like it may not be possible.
I just went out and measured ours and here's the measurements.
The long arm with the head on it is 61" end to head.
The Shorter arm from the vertical upright to the motor arm is 50" center to center of the pivots.
The adjustable arm (that folds in the middle to lower the awning) is 24" center to center.
The pneumatic shock is 24" center to center.
Measure yours to see if it's about the same.
Gotta go campin!
08-29-2016, 08:49 PM
X2... sure does look like the arms are in the lowered position in the photos.
2021 Cedar Creek 37MBH
2020 F350 Powerstroke Super Duty Lariat Crew Cab
Northern NJ - God Bless America!
08-29-2016, 09:16 PM
You said you can't raise it. Can you grab a corner and pull it down? If it is not locked down you should be able to pull against the shocks and the arms should slide in where the black lock knobs are and the corner you are pulling will go lower. I know that is not you need but just trying to see if it is bound up.
08-29-2016, 09:45 PM
Originally Posted by ilmor
Now that is how it's supposed to look!!! I'm guessing that not all the right parts were used when this thing was assembled at the factory?!? I read in an older post of a very similar issue and the guy said that Forest river took care of the problem through his local dealer. I believe the on support arm was 4 inches too short. I hope I can get a local dealer to take a look at it and maybe get it fixed... Thanks for the reply!
09-01-2016, 06:10 PM
Problem solved. Found out they installed the wrong size awning braces from the factory!!! They are sending me the correct ones. Thanks for all the input.
09-02-2016, 08:57 AM
Thanks for letting us know what the problem was.
What size did they install and what size are they replacing them with?
Also, do you have to replace anything else, like the gas strut or the adjustable arm?
Gotta go campin!
09-02-2016, 09:21 AM
I'm not sure on the size yet. They just said they are sending me the correct ones. And I believe that I only need to change out the arms.
09-02-2016, 09:31 AM
Maybe wrong awning -----------
Maybe wrong awning material. Maybe to awning material was replaced and the replacement awning is too short!!! Just my guess.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
09-02-2016, 10:11 AM
Molson,changing the arms is Not a Cakewalk,it is advised to secure 2 Helpers for this job! There are spacers,nylon washers,and pins that need to be lined up while trying to compress the gas arms and all the linkage! Even with 3 be Very Careful! Youroo!! PS make sure the Fac sends you NEW "Top Hat Clips" for the Pivot Pins,The Clips are a "ONE Time Use" item!
09-02-2016, 10:28 AM
Just a note. The valance is supposed to hang straight down from its slot when extended (aids in water not pooling). That means the awning should not be extended till it stops. The referenced picture posted shows no valance hanging down and due to installation restraints may be what must be done anyway.
