Old 12-02-2013, 06:36 PM   #1
new member with question
I just acquired a 2006 Rockwood TT 8295 ss. The kitchen/couch slide runs in an out but I can't seem to find a manual back up location. Any one out there to point me?
Ursa Major is offline   Reply With Quote
Old 12-02-2013, 06:41 PM   #2
Welcome to the forum from Dawsonville, GA. When the slide is open there should be something that looks like a small T sticking out where you would connect a turning handle and manually retract the slide by turning it. Necer hard to use this before (Hope I don't jinks myself) LOL.
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
Old 12-02-2013, 08:14 PM   #3
where do I find the handle? under the couch? there is nothing on the out side either on the slide or in the wheel well to indicate a manual system. I am afraid this one not have one and hope I'm wrong.
Bear
2006 Rockwood TT 31'
Old 12-02-2013, 08:30 PM   #4
LKicklight's Avatar
Access Panel
The factory left a cut-out on the underside of our Crusader 270RET for access to the gear box and motor. Check to see if in fact you have an access panel there, if so, you will need a ratchet and a socket to turn the gear box drive: Does the motor no work at all?
Bear
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 12-02-2013, 08:34 PM   #5
Fulltime family RVer
Often times it's laying in a storage hatch somewhere. If you ever had scissor jacks, it looks a lot like a big version of that. Mine reminds me of the same handle/thing that my pop-up's jacks were, only much bigger.
On edit- my manual slide port is on the opposite side of the camper to the slide out itself, right next to my entry door.
Old 12-02-2013, 08:38 PM   #6
fyi, the slide does work. I'm concerned about getting it out, loosing power and getting it stuck out. I guess if it gets stuck out for more than 4 hours I need to seek a mechanic's help immediately.
Old 12-03-2013, 09:02 AM   #7
nuisance's Avatar
Welcome and you are going to fit in here great.
If you are interested in going to rallys check out the rally page on here. would just love to have you come and meet you.
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is online now   Reply With Quote
Old 12-03-2013, 09:08 AM   #8
EricInColorado's Avatar
10 points and a win to the new guy!!!
Eric, Tara, and most of China
2013 Camping Nights: 2
2014 Camping nights: 31
TT 2014 Rockwood Roo 183
TV 2012 Nissan Armada
EricInColorado is offline   Reply With Quote
Old 12-03-2013, 10:13 AM   #9
BamaBob's Avatar
First welcome to the forums!
How did you acquire the TT? New?, Used?, Dealer?, Private seller?
You could always go ask the seller - especially if it is a dealer.
That said, the crank could be anything from a socket attachment of a 4" extension to a actual crank bar - it is probably located in your basement (some will clip to the side)
Having said THAT, here is a tip: buy a socket + 6-8" extension that fits the manual slide crank. Take 18v cordless drill as backup. Problem solved
Having said THAT, in 6 years of using slides (Knocks on wood) I have not had a slide motor fail (they will operate on battery power BTW)
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
