Old 01-22-2016, 03:16 PM   #1
Unhappy New owners of Wolf Pup-- discouraged
My partner and I just bought this little 2016 trailer last month and hoped to find a warm place for a couple of weeks. We have experienced so many problems, both with the trailer and the Kia Sedona 6 cyl. tow vehicle that we think we've made a big mistake. We both have some experience with trailers and towing but this isn't much fun. It's a lot of WORK. And of course the weather has been pretty cruddy even in the deep south.
BarbandLinda is offline   Reply With Quote
Old 01-22-2016, 03:24 PM   #2
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
There are a lot of folks on the forum that can help you if let us know what kind of problems you're having. I hope things work out for you because there I so much fun to be had.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 01-22-2016, 03:40 PM   #3
Hitching up has been a real pain every time so far. We have an Andersen hitch which was highly recommended by friends who RV everywhere. I believe it is a good set up but we might not have gotten good instructions. Definitely need to return to the dealer for further help. The LED overhead lights in the trailer blew out in the first 2 days. One of the stabilizer jacks was bent apparently, when we took delivery of the trailer so it never hits the ground flat. Another dealer issue. The dang water heater is really inaccessible for the two of us slightly overweight people, one with a bad knee and one with a bad hip. You have to lift up the end of the bed, have someone hold it while the other crawls under to the very front of the trailer to start the H2O heater. Needless to say, we're getting by with cold water.
Old 01-22-2016, 03:54 PM   #4
Lloydg's Avatar
It looks like you have a couple of issues that the dealer should be able to help you with. I.e. hitching up, lights and jack. The water heater is hard to understand. What kind do you have? If it's a Suburban, you should be able to access an on/off switch from the outside by dropping the panel and flipping a switch. Maybe another Wolf/Pup owner can provide some advise. If truly you have to crawl under the bed to reach the switch, I'd be asking the dealer to remount it to a more accessible location. Most campers are helpful in these matters. Ask around for some help.
Old 01-22-2016, 04:52 PM   #5
fonzie's Avatar
For more help, what is model # of trailer you have?
Fonzie
Old 01-22-2016, 10:51 PM   #6
It's a 16FQ I believe.
Old 01-23-2016, 06:44 AM   #7
bikendan's Avatar
i'll bet the frontal area of the Wolf Pup exceeds the max of the Kia.
Equalizer WDH
Old 01-23-2016, 07:14 AM   #8
fonzie's Avatar
Here a good instructional video....look at 4 minutes interval for water heater electric operation...
Fonzie
Old 01-23-2016, 07:22 AM   #9
fonzie's Avatar
Your Kia Sedona is rated at max towing of 3500 lbs and your trailer GVWR is 3954 lbs. Just pulling your trailer empty (2919 lbs) is already close to max towing capacity. Probably both car dealer and RV dealer told you "yes it can pull that".....
http://www.forestriverinc.com/produc...elID=1332#Main
http://www.kiamedia.com/us/en/models...specifications
Fonzie
Old 01-23-2016, 07:38 AM   #10
fonzie's Avatar
Also have a look at your owners manual for towing trailer starting page 5-81 attached...
http://www.kia.ca/content/ownership/...5sedona_en.pdf
Fonzie
