Like this app very helpful. Just had our new fifth wheel delivered last weekend. It is on a permanent site at the lake. After hooking it up our water pressure is low. Checked water source and 50 PSI. Removed 50 psi regulator from line and still did not help. Is their some type of regulator or reducer built in these units? Only getting about 27 psi.
I had checked the faucets and screens. Also has two ports for the quick connect hose outside and same issue. If I use the fresh water tank and pump I have excellent pressure. The camper is for permanent usage so I would not want to have to do this every time.
